Multi start threads
nickbe10
Hey Folks,
The guys down in our Gundrill dept. just had a whoopsie and destroyed a 4 start thread on one of our Drill Tubes on a BTA STS (Single Tube System).
The lathe manger has asked me to see if we can program a new thread if we cut back the tube to "fresh metal". This is something I have yet to try in MC. Can someone point me in the right direction? Is it even possible? We have a Mori NLX single turret with C and Y.
Thanks for any help.....
Yes possible, but the question is do you have to match existing threads or just new threads? If Matching existing threads you better pack a lunch using a lot of xxxxm and be extremely patience. I did this on manual lathes 20 years ago and it would take a better part of a day to fix some of the old parts the paper mills would tear up. With a CNC is becomes more tricky as you cannot change the rpms once you get started. Commit to a RPM and stick with it. Adjust your Z until you get the pitch matched and then just take your time sneaking up of the diameter. I have made molds and then went to the optical comparator to see what each .001 adjustment was doing sometimes. Now if not matching just a matter of programming the number of leads in Mastercam and it will give you code needed to help you get it done. Not sure about the Mori, but other machines have canned cycles that will do Multi-Lead threads with a Value as part of the threading cycles.
"Q" is the value that you would use to shift the start angle.
This does not have to be used with a canned cycle, G32 will also work.
Also, Your 1st start must include a Q value. I don't think that Q zero is assumed by the control.
Also, I used to home my C-axis before doing this even though I wasn't threading in milling mode.
G76X_Z_I_K_D_F_A_P_Q_;
I : Difference of radiuses at threads
K : Height of thread crest (radius)
D : Depth of the first cut (radius)
A : Angle of the tool tip (angle of ridges)
P : Method of cutting
Q: Shift angle of thread cutting start angle
