All Activity
- Today
Monkey Doctor joined the community
Remove the solid history.
Nick.L joined the community
AHandler joined the community
dp25 joined the community
martincho90 joined the community
Eric S73 joined the community
Scott_B joined the community
Guilty as charged.
amit nirwan joined the community
Chatingly joined the community
- Yesterday
Slykdexia rules KO!
Zip 2 Go is the utlity in Mastercam that share files with all the settings along with post, machine and control definition and if wanted the Machine Simulation file. Simulates correctly on my end. The axis travels and limits are all wrong and need to be fixed other than that without a Z2G cannot tell you why you are seeing the issue you are seeing.
Chamfering 45 degree Wall Around All Four Corners of a Blocks Face
JB7280 replied to zachdem1000's topic in Industrial Forum
Why not 2D swept? -
I try to always finish anything flat with a flat end mill. when surfacing i always try to use as much on the radius as i can. try searching for some online calculators that will help you figure out step over vs ridge height. when machining hard materials, surface speed varies a lot depending on how much material was left being vs tool engagement. stock left behind will always affect step over distance.
I prefer to teach someone using a file of theirs...so much YouTube content, some is really good, some falls into hack territory...I don't bother with it anymore. There is no straightforward answer... How much stock after roughing? Varies, are there other operations to be perform, stress relieving, cryo, going to another machine for finishing...and more How much stock to leave after after semi? Again, see above but then add material type, allowance for part movement...and more Stepover? Size of tool, style of toolpath used, material, finish requirements...there are scallop calculators out there... flat surfaces general cut paster with flat or bullnose, geometry dependent... and for all of the above....machine abilities...what can it hold? There are more answers to these questions than just X, Y, Z
Hi experts i have some questions regarding 3d surface machining . - how much stock to leave after roughing operation -how much stock to leave after semi finishing operation -the scallop high (step over) in finishing operation: some says that the step over should match the chip load per teeth : https://www.youtube.com/watch?time_continue=253&v=XSiPWq4Osmw&embeds_referring_euri=https%3A%2F%2Fwww.ultrapolishing.com%2F&source_ve_path=MzY4NDIsMzY4NDIsMzY4NDIsMzY4NDIsMzY4NDIsMzY4NDIsMzY4NDIsMzY4NDIsMzY4NDIsMzY4NDIsMzY4NDIsMzY4NDIsMzY4NDIsMzY4NDIsMzY4NDIsMzY4NDIsMzY4NDIsMzY4NDIsMzY4NDIsMzY4NDIsMjM4NTE&feature=emb_title -when finishig : -is it better to machine the flat surfaces with flat end mill or use a ball nose end mill . -Is it better to finish all surfaces using the same ball nose end mill with the same toolpath if possible , or use separate tool diameters with different strategies. I will appreciate your help
NAKAMURA TOME AS-200L PART CATCHER PROBLEM
riverhunter replied to Tamir Alon's topic in Industrial Forum
We recently purchased our third AS-200L. and use a older MP post. who did you purchase the post from ? We would like to purchase a good post for this machine. ( our local reseller isn't of much use. -
Tamir Alon replied to Tamir Alon's topic in Industrial Forum
Thanks @JParis There is no option for Canned Text option or a Misc Int/Misc ... on this post. I guess i will have to ask for special of my dealer. -
It's rarely the complicated 5 axis toolpath that's going to bite you! It's normally the fact that you fat-fingered subtracting -.020 from the Z origin, and accidentally told it -.2!
Yeah, I have a 32" curved as my main monitor as well. I use my laptop as my second screen, which I have on a cooling pad to bring the level up. I often don't have Mastercam spread full sized across it, as with my seating position, I can only comfortably fit about 60% of it in my view (without turning my head), so I used the side of the monitor for HSM Advisor, excel, etc.
Just checking - are you the machine operator at gcode's place who changed the Z global and argued with him to not change the tool length?
I did and if you read the topic is states opinions as such we are are entitled to have them. I have run and operated machines for most of my life I am not a cartoonist programmer. I speak from over 35+ years of hands on manufacturing experience. Develop the process and stick to the process and you have the best chance to be successful. Deviate from that process and the chances of a problem increase every step you get further away from that process. Not sure why in the world you took it personally and started the name calling, but if trying to tear others down to build yourself up is your way then keep at it you seem to have it mastered. For the record I know I am no one special and never make the claim to be anyone special. We are all one all crap away from being the worst. I do know what I know and can back up what I know by letting my work speak for itself. I need to feed may family and keep a roof over our heads. I didn't choose this path it choose me so I am just trying my hardest to follow it and keep doing the best I can. You are some keyboard warrior, but how about stepping back and walking in some of our shoes and have to make some of the tough decisions we have to make then you might back up and realize my opinion is not picking on the operator it is what I think is the safest way to run and operate a machine.
They have a deal at Sam's club right now. Both LG and Samsung have 32" Curved monitors for $180. My company just bought a bunch of them and we got mine hooked up yesterday. It's a night and ay difference. But, we were also coming from using 22" ViewSonic's. I left the 22" on the side of the curved monitor, as a dual monitor setup. Had to throw a few books underneath it to get it up to the height of the new monitor. But i love the setup. This is my first curved monitor that I've used, and I don't think I'll ever go back to using a flat. As mentioned above, it would be difficult to "Share" a screen for meetings, Teams, or something along those lines. But that's not what I use this monitor for. So they work great for us!
