All Activity
- Past hour
Okuma rookie started following Okuma OSP 7000
Hi all I have a LU-15 okuma with OSP 7000i but am struggling to write an internal threading program for M36. & also M42 any help on this be greatly appreciated as I know there is a lot of Smart cookies on this site cheers Matt
Change the overall length of your tool in your program and re-post. Best way to check is to use a known gauge on the machine to check for these type of issues. Make a block with different angles and then do a shim check at each angle to ensure the changes you have made are exactly what you were thinking before cutting the part.
Thanks for the call out, looks like Dylan beat me to it Been onsite a bunch lately and haven't had time to check the forum for a few days!
Pragmatically, if you've programmed your part to what you believe the center of rotation was and then find out that it's not the real center of rotation, if you don't have TCPC/Work Correction, I would move the plane (or model) in your CAM system to the Real center of rotation and repost. You can hack around trying to do individual work offset corrections, but if you're using simultaneous 5 axis motion, they'll all be wrong. Moving the model in CAM will ensure that no matter what you do, it'll be correct without fiddling. That's why TCPC is worth what they charge for it!
- Today
You'll need to adjust either your work offset or your tool length offset.... best I can recall anyway since i never program COR anymore.
Likely best to get your Applications Engineer in to help configure the machine correctly.
Thank you for your comments, if I don't have this option enabled, what can I do to adjust it? I'm out by +0.025"
Worked for me. Thank you!
jerrymac joined the community
Stuart Jones joined the community
Yeah why I get work is this very reason. At least 20 different times I have had to go in and help dial in machines after this was done.
Break it up on these machine is standard practice. X Y and C should be possible with the correct post and toolpath. 3 Axis toolpath probably not would need to use a 5 Axis toolpath set to a 4 Axis output and that should give you what you need, but will need to have a 5 Axis License to do it.
I hope you billed them driving time to and from your 30 second service call
At my old place we had to call a service guy because the machine wouldn't come out of emergency stop There was a pile of boxes that had fallen over and pushed it in by the tool changer magazine behind the machine
tiziano joined the community
Basic Lathe Tool Libary
clintonhudson replied to Derek KMM's topic in Machining, Tools, Cutting & Probing
Thanks for your sharing. This is what I am looking for. -
clintonhudson joined the community
I wish I could remove the common offset from the offset list. I had to drive 3 hours on a Saturday because "..we don't know what is wrong with the machine... no there isn't ANYTHING in the common offset...". Emphasis theirs. 30 seconds after I arrive, problem fixed and I'm headed back home. Uncool.
Christopher Mosley joined the community
christian audet ducharme joined the community
christian audet joined the community
- Yesterday
If FANUC options are installed in the field, the FANUC Engineer will not configure them. He or She will only turn them on. It is up to your builder/dealer to configure them. Why is that you ask? Ask the guy at Haas that decided to call ANY single rotary axis "B" axis... he's got a part time gig at a few machine tool builders... I'm sure of it.
MichauN joined the community
Machine - Okuma LB3000 MYW Y-axis +2.76” / -1.77” We have a part that can be machined complete using XC moves, but XY moves would be more rigid and precise. Mastercam does not output X+Y+C moves as far as I know. Aside from breaking up the toolpath into multiple sections, is there a way to limit how far Y tries to go plus and minus? Any suggestions are appreciated. Thank you
Chamfering 45 degree Wall Around All Four Corners of a Blocks Face
Leon82 replied to zachdem1000's topic in Industrial Forum
flowline wont like all 4 together. you can do them separate or try waterline or raster -
rgrin replied to zachdem1000's topic in Industrial Forum
3 axis mill surfacing a large chamfer? 2D Swept all day for me -
#Rekd™ replied to zachdem1000's topic in Industrial Forum
Flowline? Or can you use a chamfer end mill and just use contour? -
If I understand what is happing either way will get the job done but adjusting the WO common is risky if he forgets to set it back. I've made that mistake more then once. I think a program stop before and after the toolpath and then using the TLO to make the adjustment would be the best way.
No It used to be but several years back they began charging what I am told is mostly a nominal fee..it cost time & effort to keep it up and add things to it
Make a path that leaves .05 and a finish with a. Force tool Change. Then you can repost after the feature is known to work
is it free?
