All Activity
- Yesterday
MachSim, CAMplete, Vericut // Cimco Probing, Productivity+
ikertx0 replied to ikertx0's topic in Industrial Forum
I have asked the price of Vericut and they told me that it costs 30k. It seems excessive to me, at least for a freelancer. I had the idea that the price would be around 10k -
VERISURF TOOLS For MASTERCAM 2024
ikertx0 replied to Verisurf - Ernie Husted's topic in Industrial Forum
sent form to wait for download and try verisurf -
Thank you, I have created some more stock model in half so that the load is not so much
I have to make a thread that I have never made before. This is a left hand acme thread 3 threads per inch. Must have 3 entries Can anyone help or teach me? Regards https://www.dropbox.com/scl/fi/rqz57ac68vegfbinuwxjs/Acme_Thread.mcam?rlkey=m65bsp5fjkre4tgm9k04qzwju&st=rc4hw7bq&dl=0
Morph between 2 curves with no extra geometry created in a 3 Axis output and call it a day? Not exactly the same, but would get it done. Sorry out of room to post a screen shot here is a link to the Dropbox file. I did try sweeping a surface and no luck. Ajmer has a good solution. Link
eltklas started following Programmatically Create A WinForm Gui With C++/Cli
Mazak Mazatrol Matrix II User Defined M-Code
crazy^millman replied to RBrooks8808's topic in Industrial Forum
If they are optional then you will need to get a hold of Mazak and pay for them. They will then send you codes to unlock them or send someone out to do it. It is all about $$$$ with any builder today. -
CADCAM3D5AXIS replied to Verisurf - Ernie Husted's topic in Industrial Forum
Yes Ernie you might as well add it to the collection. Thanks For All You Do Regards CadCam -
File?
When you switch it to Y output it wants to gouge the part and doesn't follow the chain.
so you can cwich change for Y out pu on this settings
The C would work but it is too jumpy/leaves a bad surface finish. That is why I want to lock the C and use the Y to cut it.
madinatul munawaroh joined the community
Ly Ngoc Binh joined the community
I have a haas st30y and am trying to put a radial pocket on the side of the part as pictured. It looks good on mastercam but wants to gouge into the part on the machine. I need to use the y axis to put the feature in. I tried c axis contour with y axis also tried mill countour with y axis output. Both want to gouge into the part. Any ideas of what’s going on here?
Jese joined the community
Christopher Berghorst joined the community
take a look at this file i created a silhouette boundary from the front added a 0.001" rad in the corner to make the spline, next step, a little nicer then created a spline from that draft surface then trimmed it from the top with the boundary i created ajmer_ihs_Flowline.mcam
- Last week
shaneoswald3 joined the community
Attached is an operation from a file I made last year. I was able to make a single surface from the 3 solid faces and use a flowline operation that has worked really well and gives me the exact motion I want. Another part with the same type of feature has come through and I can't for the life of me remember or replicate how I did it the first time. When I use Loft, it creates 3 separate surfaces, just as if they were the solid faces. I've tried everything I can think of with surface, solid, and mesh tools and I'm stumped. I can tell I extended the surface because of some "wave" going on, but I can't derive anything else from it. Flowline.mcam
Hello, I hope someone sees this and can help me. I have been given the task of adding 2 new M-Codes to some of our machines. CNC machines aren't my strong suite. I generally program PLC's and robots. Mazak shows several M-Codes that aren't assigned a function. We would like to use M66 and M67. I have looked through the PLC program of a machine that someone started this process on and I can see the M66 and M67 used in several locations. If M66 and M67 are located in the correct locations inside the PLC to perform the function we need will they work when called from the CNC controller or do they need to be enabled somehow?
RBrooks8808 joined the community
ID Roller Burnishing
crazy^millman replied to scottm085's topic in Machining, Tools, Cutting & Probing
https://www.elliott-tool.com/metal-finishing/burnishing-tools/id-multi-roll/ https://mollart.com/featured/id-roller-burnishing-tool http://www.brightbright.com/id_burnishing_tools.html Here are a few others -
That's what I'm wondering, if the post can be changed to read the length offset instead of the diameter. Then I should be able to make the change on the fly.
I have not. I will give them a call. Thanks for the recomenndation!
Verisurf - Ernie Husted replied to Verisurf - Ernie Husted's topic in Industrial Forum
Is anyone using the Verisurf 2024 free tools? Are you ready for Verisurf 2025 free tools? New web page for the Verisurf tools? https://www.verisurf.com/verisurf-tools-for-mastercam/ -
cncappsjames replied to scottm085's topic in Machining, Tools, Cutting & Probing
Have you tried Sugino? https://www.sugino.com/site/roller-burnishing-tool-e/ -
hellsing36 joined the community
MBragg joined the community
faisal syamsu joined the community
Orsolin37 joined the community
Upgraded from HLE to Industrial issues.....
Pgreenlaw replied to Pgreenlaw's topic in Industrial Forum
Disregard..... After opening the license activation wizard and looking around, I saw the license "deactivation" option and deactivated the HLE license. Probably should have tried that before emailing my reseller or making this new topic Maybe this will help someone in the future with the same issue.- 1 reply
- 2
Purchased MasterCAM after using the HLE version for a month or so. I completely uninstalled the HLE version and installed the 2024 Industrial version with update 6. Received my License number and activation code. Ran those through the license activation wizard successfully. When I launch MasterCAM it launches the HLE version and pulls my old HLE license and I cannot figure out how to launch the industrial version and new license, I have emailed my reseller and I'm sure he can help me with it but in case he doesn't get back to me in a timely manner I wanted to reach out here. Thanks guys
Does anyone have a recommendation for an ID roller burnishing tool for a 14.5mm blind bore roughly 3" deep? I have tried Cogsdill and they are giving me a 4-6 week lead time. Cogsdill is the only roller burnishing tools I have used, just cannot wait on their lead time this go around. Thanks.
