Benchmark
Roger Peterson
With a laptop your limited, I think you are likely as good as your going to get.
That 2.0 Ghz chip probably only has 2 meg cache on-chip, that is a HUGE limiting factor that can only be remedied by a better CPU with larger on-chip cache.
X2 MR1 SP2 best number was 6:44
X3 PC2 best number 6:10 with for the first time through on my system.
:41 Sec with X3 PC2 second time through.
Still an inprovement. Granted only :34 sec, but an improvement is an improvement.
  • 3 weeks later...
Not bad,
I have my Q6600 2.4 ghz, FSB 1066 OC'd to 3.0 Ghz, FSB 1333
My original time of 7:12 was marked down to 5:30
I wound up having to change my mobo out, the original one I purchase the Intel D975XBX2 was a good board but I kind of goofed when I bought it from on overclocking standard and as I slipped my second video card into the system, realized that board supports the ATi Crossfire technology and not Nvidia's SLI, I have 2 NVIDIA GTS8800 extreme cards.
So I bought an Asus P5N-D, which is very OC'able.
With the added FSB and addition voltage required my CPU temp never got above 40°C
and the hot Northbridge 750i chip set never got above 39° C either.
[ 08-31-2008, 10:06 AM: Message edited by: JParis@CNC Programming Solutions® ]
I just ran my year old Dell M4300 @ 6:45 after making the total tolerance to .0001 on all 3 operations then regenerating (X3). What would be considered a decent time using a laptop?
Off subject really quick, has a lot of you changed to XP Pro SP3?
Dell M4300 precision laptop
T7700 @ 2.4 GHz
4 GB of ram
Nvidia Quadro F360 M
XP Pro SP2
All my computers are on SP3 now..
SP3 was mostly security upgrades.. I have never seen any cliams to better performance nor have
I noticed any with my computers.
Bugusmill,
I actually had a worse speed when I first got it back today. 7 min 38 sec. (i almost blew a nut) mad.gif
I called the tech that installed the new chip and he walked me through this.
I went to intel and downloaded a bios flash for my motheboard. The (1 yr old) board needed it for the new chip
(BTW if you flash your bios with the wrong update you will need a new board apparently)
Then it gave me the proper 5min time
It's a straight up Mastercam time no BS on it.
I "tweaked my 2.4Ghz chip a "tad" I overclocked the standard settings
from 266mhz x 9 = 2.4 Ghz
400 X 8 for 3.2 Ghz
course I had to mess with voltages and stuff as well.
My original 7:12 time for this set up has been knocked down a bit.
Don't try this at home
Nah, you see the temps on that.
I am no where NEAR even starting to get close to burning anything out.
woo hoo, I thinkI can get to 3.6 Ghz on this with only air cooling. I have 11 fans in this new I just bought.
Check out the Antec 1200 for a computer case.
Played around with overclocking for the first time ever today. Using the stock Intel Core 2 Duo E6750 2.66 Ghz CPU (333 X 8)and stock cooler. With no overclocking X2 ran in 6 min 25 secs. X3 ran it in 6 min 30 secs. Overclocked it mildly to 3.00 GHz (375 X 8)and X3 ran it in 5 min 55 secs
My usual temp without ocing is around 38C idle, and 52 under load. With ocing it was 48 and 68. I set it back to stock settings until I can get a high performance fan/heatsink. Since I am new to overclocking what temp should I be trying to avoid?
Some chips are more prone to OC'ing than others.
The Q6600 G0 stepper is a really good chip. That was why I originally purchased it.
Thermaltake, Zalman and a couple of others make really good CPU coolers. I use a Zalman 9500.
Your stock temps while not considered "hot" are warmer then I;d like to see when starting out OC'ing a system. My system idles right around 25°C, if you look at the screen shot, those temps were recorded idle while OC'd to 3.2 Ghz.
Generally, under load your CPU should not get above 65-70°C, under 100% load.
Staying around 50°C at idle while OC'd would be stable place to be. Most CPU's should not get above 90°C, if you're running that HOT, it's way too hot.
Cases are VERY important, you MUST create and maintain a good airflow.
Check out Prime95 for a good stress testing utility, run it in torture mode.
Also, see if you can lower your voltages may help alleviate some of the heat as well. A good cooler and some thermal paste, I use Artic Silver 5, good stuff. I am also going to lap my heatsink to make certain I am getting as much surface contact as I can.
I checked out that Tom's hardware site. The Intel max temp spec is 72C, so its right near the top end at 68. I knew it would be high with the stock Intel cooler even though I used the Arctic Silver compound. Thats why I only went with 3.00 GHz to try it. I would like to get it up to 3.2 or 3.4 if I can keep it stable. I have a good Cooler Master Centurion case with 2 fans and a place for a 3rd fan. Going to neweggs site next for another case fan and CPU fan/heatsink.
