BEST FILE CONVERSION FOR MC8?
batraul
batraul,
There are a number of threads in this Forum which discuss the best format for conversion. Using the most up-to-date software can give you more benefits for file transfers than anything else. Always try to get the cleanest, most informative file format possible.
PARASOLID/IGES/DXF/SAT/UG (Anyone wants to add a type of file?)
Of these converters listed, Parasolid is the cleanest form of geometry available to convert into a Mastercam file. The UG files can be exported from UG as Parasolid files. There are STEP, UG and Pro-E direct to Mastercam converters, but they are add-on costs to Mcam. Even without solids licensed in Mcam, the Parasolid file is cleaner than IGES because there will be no gaps between surfaces or overlapping lines and curves. There is typically a lot of "cleaning up" to do to an IGES file, before it can be machined accurately. DXF doesn't support surface data. HTH smile.gif
[ 05-09-2002, 11:29 AM: Message edited by: Peter Scott, Services 4 Automation ]
