2D pocketing with multiple chains
Thad
I'm looking for an efficient way to cut the pocket in this plate. The green profile is burned out. This overall part size is 18 X 15 and the pocket is 1" deep, so the burnout is worth avoiding. Normally, I create a chain just inside the burnout that I can chain along with the pocket walls to contain the toolpath. If the 2 chains are too drastically different, I end up creating some extra geometry to get everything cut.
Using contour with multipass cuts alot of air since there isn't an even amount of stock all around. Pockets with 2 chains always seem to waste moves by recutting areas that have already been cut. The next best thing I've found is a Morph Spiral pocket. I can never get the tool to step over as much as I'd like. It seems that you're at the mercy of how much the 2 chains differ as to what kind of step over you'll get. Trimming the toolpath causes the tool to plunge down into stock when re-entering.
So, I'm looking for advice on how you handle this type of situation. What would you do?.
Thad
I had a simular situation recently. I ghosted a pocket operation to simulate the burnout. Then I used surface/high-speed/rest-roughing to machine the remaining stock.
Using Mill level 1, I think I would stick with the contour with multipass or other methods, but use high-feed to speed up the air-cutting.
I'd offset a green chain by a tool diameter plus a safety distance and select 2 chains for one of the pocketing options (probably morph spiral).
You can get aggressive with cutting if you choose to move in steps on z (say every .25).
Or use a feedmill to do the contour and then rest mill with smaller diameter tool.
Get outta here Del
no seriously because i do mess around with the 3 axis proto traks.if you offset countour the inside to stay away from it, i am asking if you could use the area option and then choose the type of path you wanted.isnt that the same thing.im just wanting to learn you dumbmill biggrin.giftongue.gifbiggrin.gif
