Contour Collision
Thee Rickster ™
X2 MR2 SP1
I have a contour profile that has 4 small profiles that are closer then the diameter of the cutter i am using(1/4 cutter and .13 gap between contours).
When I chain them and run the path the tool collides with the contours where they are close to each other.
Why does it do this?
With out changing geometry how do I tell the path to avoid collision?
(forget the lead in collisions in the picc I will take the lead in off)
Thanks in advance
Rick
Yes.
gcode, i don,t do alot of 2-d stuff.
But I only have ever had this issue in Mastercam.
(in the last 2 softwares I had used this was a standard non issue(thought they all compensated for multiple contours, Surfcam being an example from ver7. and on??))
I can get MC to do the same result by adding extra geomtry around the profiles that I am using, and pocketing with a 5" step over.
But now I have an added toolpath cutting nothing.
Is there a way to delete the extra toolpath that is created by using this pocket method?
Here is the pocket with 5" step over
Personally I'd just copy the geometry to a new layer and draw what I needed..
You could use your pocket toolpath and use the toolpath editor to supress the outside path, but
drawing the neccessary chain would give you much bettr control
Mr. M,
jon banquer was negative toward MC when talking about toolpath editing, an he is not a guru with smartcam. I used it to cut hundreds of complex molds in the past, but then again I can in 4 different/any software
I an fluent in smartcam and yes in this case it would work. i would just trim the toolpath geometry. But even in smart cam it avoids collisions on the 2-d profiles as i illustrated in the 1st 2 pics.(the toolpath editing in smartcam is awesome, the rest of the software sucks.)
no need to edit the path
Rick
I just want to contour with ease
Rick
cobra
i will experiment with that sometime. I don't have margin for error. Rush Job
gcode
I figured out how to edit the un-needed pass from the pocket path I created. It locked the path but as long as it works, I will use this method untill Mastercam enhances or fixes the contour issue. thanks cheers.gif
Rick
yes!!!
Although I haven't used it yet in X3..it is actually about the same as the one where you used to right click on the NCI file to bring up the editor...
Kinda tricky but it will work...
Right click on the ops...very bottom..
Toolpath editor...
Well heck, I read further and see that Gcode already told you where the editor was lol..
BTW this is for Roger below..
Great trick!! I don't do too much 2-d at all but I will remember that one.. cheers.gif
[ 08-13-2008, 09:57 AM: Message edited by: Murlin ]
Just do a 2d pocket, turn off roughing, uncheck "finish outer boundary". I know people that use this all the time. If you think contour should be enhanced to do this send it in. I use 2d/3d contour to cut vents with a ball end mill all the time that requires it works just like it currently does. And to be honest since it is easily accomplished via pocketing I don't really know that it's neccesary. The only downside of the pocketing toolpath is you can't place your start position exactly where you want it.
JM2C
Roger,
When I uncheck "finish outer boundary" it ONLY finishes the outer boundary??
Exactly the pass I had edited/deleted, kinda funny. I don't know what it thinks the outer BND is but it does the exact opposite of what I want. confused.gif
So adding/creating the extra pocket geometry and editing the toolpath is what I will continue to do.
As an enhancement request it is pretty standard (common)feature.
thanks
Rick
Yes you can... break the entity were you
want the toolpath to start into 3 segments
making the middle segment about .100 long.
Start yout chain on that segment.. Mastercam
will start the pocket in the middle of that segment.
gcode
do you want to mess with it and see if you can get the start point (on the edited path) on any one of the straight lines of the contour?
it starts on the outer bnd and I cannot get it to start the inner bnd in a different spot.
i will make a small file with the path I edited
and the originalthe (whole file is 160 meg)got it down to 2-1/2 meg
BTW when I remachine with the same path to a 1/8 cutter it works perfect
Rick
