helical toolpath with cutter comp active
HEAVY METAL
I can't figure a way to create a toolpath to follow a helix I have drawn with cutter comp active. the helix is 2.7 mm pitch wraped around 560 degs. I can only get a correct toolpath when compensation is set to off. so everytime I want to bump the cutter in or out i have to create new helix geometry. Is there a way to accomplish this that I am not seeing?
thanks heavy
it won't do cc because its a 3d spline.i just add 1/4 turn of Z to each 1/4 of the circle.
this is 1 turn 8TPI
( 1/2 #108THREAD CUTTER TOOL - 4 DIA. OFF. - 4 LEN. - 4 DIA. - .5 )
T4 M6
G0 G90 G55 X0. Y.1865 S1200 M3
G43 H4 Z.2
M8
G1 Z-.569 F10.
G41 D4 Y.3865 F6.
G3 X-.3865 Y0. I0. J-.3865 Z-.5274
X0. Y-.3865 I.3865 J0. Z-4858
X.3865 Y0. I0. J.3865 Z-.4442
X0. Y.3865 I-.3865 J0. Z-.4026
G1 G40 Y.1865
Heavy, Is this a thread your trying to mill? Like midwest said, Use contour/ramp and turn wear comp on. you might have to tweak the % of tool to lead in by so you don't hit the other side of the hole if it's an internal feature. I do this all the time. I use like 20% of the tool dia. with it set to tangent and maybe a 5% radial lead in and it works fine. HTH!
Have you tried using thread mill?
you can force the toolpath to start in the center,
define the pitch and lead in/lead out and it will
post a helix if your machine df and post are set up correctly
This is how I do it also.
It works great.
With regards to the helix toolpath with control, try start at centre and set start angle and arc sweep to zero. This gives you a G1 G41 to apply cutter comp, but no arc approach. As long as you start above the material it will be fine.
Works for me.
