contour formula
JSomerville
Good morning everyone. I had to go back to programming and I can't remember the formula to cut a pocket so the tool drops on center. It was something about the diameter of the tool and the lead in angle was 135 degrees. When I used this it dropped on center and cut returned to center and retracted. bonk.gif It's been a while so be kind. Thank you in advance....
Maydays suggestion sounded easier.
For pockets yes, but not for interpolating a hole and having your endmill start and end at center.
I do exactly as Mayday says for holes and it works fine. I do check "use entry point" in lead in/lead out.
why not use circle mill? start at center
+1
Well, I have one reason, there is a bug with circle mill and it's been logged.
If you drill a hole then want to circle mill but rapid to the bottom, it won't, it will feed down.
There is a work around but CNC software has confirmed this is a bug.
Tom,
I just created a 2d circle. Entered feedplane = 0 incremental. set depth to -2.0
It does not work, it feeds down from Z0 to -2
(T | CIRMILL TEST.EIA | MAZAK_410A_640M | 02-23-10)
G20
G0 G17 G40 G49 G80 G90
G91 G28 Z0.
G90
N1
( 1/2" ENDMILL AMTPID 102919 | KENNAMETAL UCDE500J5BS KC643M | | TOOL 2 | DIA. OFF. 2 | LEN. 2 )
T2 T0 M6
G0 G90 G53 X0. Y0. S4500 M3
G43 H2 Z0. M8 T2
G1 Z-2. F10.
G41 D2 X.3394 Y.3394 F30.
G3 X0. Y.6788 I-.3394 J0.
I0. J-.6788
X-.3394 Y.3394 I0. J-.3394
G1 G40 X0. Y0.
G0 Z0.
G91 G28 Z0.
M01
N2
G91 G28 Z0.
T2 T0 M6
G0 G90 G53 X[#198] Y[#199]
M30
Tom, same results: I will email my test file to you.
G20
G91 G28 Z0.
G90
N1
T2 T0 M6
G43 H2 Z.1 M8 T2
Z0.
G1 Z-2. F10.
G41 D2 X.3302 Y.3302 F30.
G3 X0. Y.6603 I-.3302 J0.
I0. J-.6603
X-.3302 Y.3302 I0. J-.3301
G1 G40 X0. Y0.
G0 Z.1
G91 G28 Z0.
M01
N2
G91 G28 Z0.
T2 T0 M6
M30
Because the genius that I am, have a heavily edited Okuma Mill post and somewhere along the line I did something that messed up the circle mill with wear and multiple passes.
So, for my Okuma, I have to use contour for holes instead of circle mill if I want to use wear and multiple passes.
It's only for circle mill toolpath.
Dave,
if you don't want to draw extra geometry, why not just give it a high feedrate for plunge, that way all your retracts will remain in tact.
I found this bug a while ago. Now I only use 3D geo.
However, still a bug and I am most concerned about setting parameters to make it work and then some day the bug maybe fixed and the parameters will act different and may be overlooked.
But, I doubt the bug will be fixed anytime soon.
