2020 Feedrate Override Issue
nperry
Anyone seen this one yet?
I never typically program an override for a finish pass, but I've seen them posting out above 100% lately when they're programmed at 100%.
If I go in and change the feedrate to something other than 100%, then back to 100%, regen, it'll post at what is programmed. This is in helix bore....haven't noticed it anywhere else at this point.
When I make my feedrate on the final helix bore pass less than a hundred percent,
it will come out as 7.5 ipm instead of 420.0 ipm.
If you put it at 100%, does it post out the correct value?
It'll post out the correct feedrate if I change it to something other than what I want, regen, change back to what I want, regen, post. It looks to me like if I create the cutter path and leave that override untouched it's posting out something above 100% until I make some sort of change to it and regen.
16 minutes ago, pro grammer said:
That bug exists in several other places in MC, too. In lathe if I change the tool number it creates quite a mess. I literally have to go in and create a whole new tool in order for the tool to post right. Many times I have to totally recreate ops in mill in order for it to take a change.
this setting is on in a default install
Make sure it is unchecked
Yeah, that's not the issue. I never have that "feature" checked. That "feature" reminds me of another "feature" they had years ago called "use default post". Boy was that a FKUP. They tool that out soon after.
I would like to see this feature on each individual toolpath.
It is useless as a global switch IMO
I use it globally, i'd rather have both.
I am curious as to the settings...
I just drew four 1" circles, circle milled them with a .500 endmill x .25 deep...
2 rough passes at 55 IPM
1 finish pass at 25 IPM
On all switches it made the correct change and changed back....
I'll double check again in the morning
Please do, and post files (or even better, send them into [email protected]).   We're currently looking at a reported issue (R-13837) where the feedrate isn't being updated unless you view the Rough/Finish page after changing tool parameters, but I don't have any records of something like this reported for disabled values, and, like JParis, I cannot replicate it.
Also, - spoiler alert - because fixing that will cause other the opposite problem where it updates the feedrate when you didn't want to, look for something like this in the next release:
So it'll act like Thread Mill, where you can lock a setting to keep it from being updated by changing the tool properties...
I wish we could have that lock button on all the tool pages as I don't use the lock feed rate button.
I'll post a file later when I can get internet.
So if you only override the finish feed rate you get the bug. But as soon as I overrode the semi-finished feed rate also then it posted correctly with both feeds
I have roughing and entry off at the moment I think that maybe what it's doing. This is on circlemill
Also depth cuts are on.
The first depth is ok. All others stay at the finish override feed
Well, I have never seen it do that before but you're file clearly shows it ain't updating...
I have messed with all kinds of setting and nope, nada...if you haven't sent that into QC, you should definitely do so...
I tried it in 2021
I tried it in 2021
Ok I will forward it to the address Arron posted.
