o/t, spindle warm up @ start of prog.
Jammer™
I have a curse.gif rebuilt fadal with 10,000 rpm spindle. In the mornings, I run a warm-up cycle with spindle in low gear before running any programs. But when running programs at 10,000rpm all day and not going into low gear, the belt sticks and makes all kinds of noise and sometimes won't even rotate. (not good) My question is: Is there a way to add something in my post that will run the spindle for 5 min. in low gear at each tool change, before next tool runs? I am using mpmaster fadal post. Thanks
2025( TRODE1RAD )
( CREATED ON 06-28-04 AT 8:56 AM )
G20
G0G17G40G80G90
( .01 DIAMETER TOOL - 15 DIA. OFF. - 15 LEN. - 15 DIA - .01 )
T15M6
S1200M3G4P?
G0G90S12000M3E1X-.6209Y.505
H15Z1.25
I THINK This may be what your lookin to do if so shouldnt be hard to incorp into post
If you are having problems with the low gear on the fadal, I would check the hoses to the hydraulics that change belts on the head. They do tend to leak and get sticky. Order a new part and replace it. Easy swap out. We normaly have to order those parts every 3-4 years on our fadals.
JIm
Okay I manually typed it, and it needs to look like (this is a 15,000 rpm Fadal)
2025( TRODE1RAD )
G20
G0G17G40G80G90
T15M6
S1200 M3
G4 P10000
H15Z1.25
Z-.09
Thanks for the input guys. I will check it out today, and let ya know the results.
Madbub,
This machine is only 6 months old. I would hope were not having issues like that yet. I will check it out though. I did already have to replace the belts. Thanks again peeps!
HI
Wow, I'd think it would be more cost effective to have the machine repaired than to add 5 minutes to every low gear tool change?? I've had to couhg up some $$ for the tree guys to get my machine up and running, but all in all it waqs money well spent.
Good luck
John
That is just messed up. No wonder the US can't compete with Asia, too busy screwing around with crap like this. Rebuilt Fadal... curse.gif that's like a rebuilt Yugo. I'm sure it looks pretty though.
Sorry for the rant...
We have had this machine for 6 months. I've had the service guys out here 4 times already for one thing or another. curse.gif
yeah, it has two pretty stickers on the front. One says Factory rebuild, and the other says Made in the USA..
I would replace M3 code with custom macro .
Not havin` Fadals (GSMF (G_d save me from ) Fadal ) i will talk schematically
Macro program gets looks like p100=7000 m333
or #100=7000 g333 or some other appropriate for Fadal way
Saves a speed s7000 setted for a tool in inner parameters
Checks if spindel turns and on what gear
if result -low gear skip and go to
m3 p* something or g4 x or whatever fadal has for wait 5 minutes
m17
if result high gear go to low gear
for s500 m3
g4 x300
m5
go to high gear
s(input saved inner parameter -needed speed )m3
m17
end
You will have a good way to use it even through MDI or in hand written code if you save it as custom macro G-code or by any other appropr. way
WTHH
Here is a program I used to warm up a Fadal. I use sub's. I left this program in memory and always over write programs being ran. This is the only one that stays in memory. Easier for the operators. The sub also moves the table and head in 3 axis moves just to get the juices flowing. Plenty of time to cycle the spindle as the table travels.
If you would like, I can email you the file.
O9999
(PROGRAM - 15K_FADAL .nc )
( 1/2 FLAT ENDMILL )
( WARM UP )
( 10 MINUTE WARM UP )
T20 M6
G0 G17 G40 G80 G90 E1
G0 G90 X-5.8188 Y7.077 S1000 M3
G43 H20 Z8.6172 M8
G8
M98 P0001 L1
G17
G90 Z8.5672
S2000 M3
M98 P0001 L1
G17
G90 Z8.5172
S3000 M3
M98 P0001 L1
G17
G90 Z8.4672
S4000 M3
M98 P0001 L1
G17
G90 Z8.4172
S5000 M3
M98 P0001 L1
G17
G90 Z8.3672
S6000 M3
M98 P0001 L1
G17
G90 Z8.3172
S7000 M3
M98 P0001 L1
G17
G90 Z8.2672
S8000 M3
M98 P0001 L1
G17
G90 Z8.2172
S9000 M3
M98 P0001 L1
G17
G90 Z8.1672
S10000 M3
M98 P0001 L1
G17
G90 Z8.1172
S11000 M3
M98 P0001 L1
G17
G90 Z8.1172
S12000 M3
M98 P0001 L1
G17
G90 Z8.1172
S13000 M3
M98 P0001 L1
G17
G90 Z8.1172
S14000 M3
M98 P0001 L1
G17
G90 Z8.1172
S15000 M3
M98 P0001 L1
M5 M9
G91 G28 Z0
G0 G90 E20 X0 Y0
M30
Hey Trevor, How ya doin man? Hope everything is goin well for you. I have a program wrote to warm up the machine in the mornings. What I am looking at doing is running the spindle in low gear for a couple of miniutes at each tool change on my high rpm programs. If this spindle doesn't get any low gear run time, the belts want to seize up.
If you want to do this while you are running a program (or before the ACTUAL program begins), you should be able to set up a flag in the post that could be turned on with an integer. If you need help, I will set it up for you. Let me know if you are running the last Fadal post I sent you.
All is well on this side of the world. Miss the beautiful green country side though.
Well you did say rebuilt, so I thought I would mention this. If it was rebuilt, the machine under neath is problay alot more older than 6 months.
Jim
