MuR0904......I think I did it
Toolfab
Check Holder chooks (CKHolder)
This chook will check one operation’s holder for interference with the part (surfaces and solids). This program is interactive and allows the results to be quickly view
Are there more pages to the details document, or was the last word supposed to be viewed instead of view? It kinda just stops abruptly on page 2.
From the MC update page:
Two Backup directories have been made in the root of Mastercam (BackupApps and BackupChooks), in the event a user wants to revert back to MR0304.
Marc Lindsey said:
If you have a "backup" and "backupapps" folder in your mcam9 folder then the patch has been installed.
I'll use Marc's quote as confirmation that my update has been installed. The wording in the instructions at MC's site is incorrect. There is no folder called BackupChooks. It's called BACKUP.
Thad
In the maintenance section, there is a lits of the bug numbers that are addressed by the sept. update, anyone got a text list of what those bugs are? Would just like to know because there are currently features I dont use, or have work-arounds for, and would like to know if there now work as the are supposed to without having to trial and error my way through. Thanks a lot guys, Have a great day
Definitely - Some help, PLEASE, a list of numbers don’t tell a whole lot! frown.gif
Along with the enhancements, the following defects have been addressed.
24579-24821-2445 -620-1337-2867-3101-3589-3797-4774-4873-747-924-925-601-2671-2861-983-25229-2934-3078-2710-3213--3365-3527-3430-3365-3527-2775-3675-3748-3801-3864-3924-4564-4564-4564-2704-4692-487 7-4874
Mark
FYI,
I just loaded the update and found a file: APPMCH9.DOC It looks like the surface machining fixes
BUG CORRECTIONS:
This app includes all corrections, improvements for toolpath/surface
in MR0304 plus the following:
#747-fix crash in Rough/Pocket quick zigzag (fix memory handling)
#924-fix FZT failure on big part
#925-fix error reporting for FZT
#601-fix crash in undercut cutter comp of slot mill w/ "flat" on tool's side
#2671-RghPock:fix gouge of plunge outside, troch cuts on, spiral inside out
#2861-fixed check surface processing in FZT
#983-fixed crash in FZT
#25229-fixed bug in memory allocation (no scallop cut found) (3d collapse)
#2934-fixed bug in edge protection (undercut) with dove mill (finish/contour)
(this one is improved but not fully corrected)
#3078-fixed crash in rough/restmill
#2710-fixed incorrect cut order optimization (restmill and contour)
#3213-properly handle "touch" case in FZT (finish/contour)
#????-speed up FZT for tool containment boundary usage
#3365-fixed incorrect view used for inc. depths when hidden faces are skipped.
#3527-fixed entry/exit arc gouge (closed cuts, finish/contour)
#3430-fixed gouge in rough/pocket
#3365-fixed inc.depth bug in rgh/pock with solid in view other than top.
#3527-fixed entry/exit arc gouge (finish/contour)
#2775-fixed project/blend gouge
#3675-fixed plunge in rgh passes (rgh/parallel, rgh/radial, rgh/project...)
#3748-fixed taper tool in FZT surface/contour,pocket,restmill
#3801-fixed gouge in sharp corner smoothing (pocket)
#3864-"
#????-fixed crash in quick zigzag (rare)
#3924-fixed "equal" case when machining vert steep wall ast 45 deg (parsteep)
#4564-fixed tcb offset inside (out of tolerance)
#4564-fixed critical depths (duplicate cut)
#4564-fixed prefilter arc error (gouge in srf/rgh/pocket motion) with FZT
#2704-fixed FZT for face mills with zero taper
#4692-fixed restmill comp to center when not using prv ops rgn file
#4877-fixed absolute feed planes in rghpock keep down effort
#4874-fixed FZT failure with large part
Mike
