can anybody write a CNC program for lathe please.?
bala_51083
The part i want a program is simple
ppl say.can i send the file to you please.
if u can help me i will be nice
I don't know much English but that surely sounds like you want harass Colin.
Put your CATIA drawing picture on the forum, it will be more accesible to everyone, and not you alone can learn but share them as well to all forum members.
  • Replies 144
  • Created
  • Last Reply
Top Posters In This Topic
I'm a lathe guy - e-mail me your drawing and I'll see what I can do. I will do a quick hand write if possible and I'll give ya a few tips for setting up the simple operation of the machine to keep it safe.
Can ya scan the "G-code" and "M-code" lists from the book and send them as well? It really helps to have the syntax the machine needs.
[email protected]
Then I will also put myself as one to aplogize as well.
A simple program for you are could be:
G0 Z.1 X-.05(APPORACH MOVE)
G42 G1 Z0( APPORACH PART AND TURN ON RIGHT CUTTER COMP)
G1 X0(MOVE TOOL TO CENTER)
G3 X3.937 Z-1.9685 R1.9685(COUNTER CLOCKWISE ARC MOVE)
G3 X3.7179 Z-3.2635 R1.9685(COUNTER CLOCKWISE ARC MOVE .05 PAST ARC)
G40 X4.0 Z-3.4(MOVE TO POSITION TURNING OFF CUTTER COMP)
G0 X4.2
G0 Z.25
Now this is not a complete program and will only make the 1st part of the arc there. If I was making this part I would make the stub end 1st roughing the radius. I would then grab that in a set of soft jaws and then do the other side. and finish the radius with either comp code like this or centerline tool code that take the radius of the tool in to account like the example above. It is hand written and done real quick with a calucator.
[ 09-27-2006, 09:29 PM: Message edited by: Crazy^Millman ]
Ahh yes, the "simple" accuracy test. If you gents have no experience on CNC machinery may I suggest you get the dude in that shop who does because according to that dwg your little test will require two set ups. BTW, little rads work just as well as big ones and only require one safe op.
This may work and it may not, depends on your control and my math(you take your chances in here man). No garunteees.
:0001
N1
(ROUGH TURN)
(CNMG 3/32 TOOL NOSE RADIUS MINIMUM)
G99
G50S1400
G0T0101
G97S700M3
G54X8.25Z.2G96S500
M8
G71U.1R.02
G71P100Q101U.005W.002F.012
N100G0G42X-.065
G1Z0
X0
G3X7.874W-3.937R3.937
G1Z-5.25
X8.25W-.05
N101G0G40X8.25W.2
G28U0W0M9
M0
N2
(FINISH TURN)
(VBMT 3/32 TOOL NOSE RADIUS)
G99
G50S2500
G0T0303
G97S700M3
G54X8.0Z.1G96S500
M8
Z-3.8
G71U.04R.02
G71P200Q201U.005W0F.012
N200G1G42X7.874W0
G1Z-3.987
G3X7.4254W-1.31R3.937
G1X8.0
N201G0G40X8.0
G0G40X8.0
Z.1
G42X-.065S600
G1Z0F.01
X0F.007
G3X7.4254W-5.247R3.937
G1W-.05
X8.25F.03
G0G40X8.5W.2M9
G28U0W0
M0
M30
[ 09-27-2006, 10:04 PM: Message edited by: ShiftZ ]
Your control may be of an older type. If it is it won't understand "R" as being a radius value.
In that case I and K are used to indicate arc rotation. It may also not read decimal places in the feed rates.
.007 would look like 70 in that case and .012 would be 120 etc. As stated before I don't promise anything.
:0001
N1
(ROUGH TURN)
G99
G50S1400
G0T0101
G97S700M3
G54X8.25Z.2G96S500
M8
G71U.1R.02
G71P100Q101U.005W.002F120
N100G0G42X-.065
G1Z0
X0
G3X7.874W-3.937K-3.937
G1Z-5.25
X8.25W-.05
N101G0G40X8.25W.2
G28U0W0M9
M0
N2
(FINISH TURN)
G99
G50S2500
G0T0303
G97S700M3
G54X8.0Z.1G96S500
M8
Z-3.8
G71U.04R.02
G71P200Q201U.005W0F120
N100G1G42X7.874W0
G1Z-3.987
G3X7.4254W-1.31I-3.7127K.05
G1X8.0
N201G0G40X8.0
G0G40X8.0
Z.1
G42X-.065S600
G1Z0F100
X0F.007
G1W-.05
X8.25F300
G0G40X8.5W.2M9
G28U0W0
M0
M30
P and Q also define the finish tool path. When they are called by G70 they tell the control to look back for the sequence of this program section and the tool follows just the path described in those blocks. G70 can also be used without a roughing cycle as long as the blocks are numbered and that it describes what you want the tool to do.
Also, do you really want a 200mm dia. part or 100mm ? If you want a 100mm sphere from a lathe then you cut the radius in 1/2..... This is a very large test object but it will cover a larger section of the machine envelope for a more thorough test.
I use a "safe start" program to tell the machine to clear the part for tool change position. It takes a lot of clutter from the program and when doing a lot of hand writing it makes it much faster to put all the prep command stuff in it. I can usually have my machine programmed and set up faster than programming it with a CAM system.
I did these from memory - I'm in wire EDM now, but you should'nt have much problem getting this going.
:0001(SAFE START PROGRAM)
G00 G40 G97 M9
G99
T0X10.Z10. (SAFE INDEX POSITION)
M99
:0002(PRODUCT 1 RADIUS OP)
(8.0 DIA ALUM IN JAWS)
(JAWS 1.2 DP @ 400 PSI)
N1(RUF TURN CNGP432 .032 RAD)
M98P1(SAFE START PROGRAM)
G50S2000
G0T0101G96S1300M3
X8.0Z.2/M8
G71P11Q12D.1U.01W.002F.011
N11G0X0(G42 OPTIONAL)
G1Z0F.002
G3X7.874Z-3.937R3.937
G3X7.4699Z-5.182R3.937(PROBLEM LINE)
(JUST USE G1 Z-5.182 TO CUT STRAIGHT)
X8.F.02
N12G0Z.2
M98P1
M01
N2(FINISH TURN VNGP331 .016R)
M98P1
G0T0303G96S1300M3
X8.Z.2
G70P11Q12F.002
M98P1
M30
shiftz, This can actualy be done in one setup if your careful and use the correct strategy. I've done lots of parts on the lathe like this. Worst case is you might have a tiny nipple left over from parting off. Just my two cents. smile.gif
MMMMMM, Dognuts....
I agree that this could be made in 1 operation but doing the radius as a "back end" type feature would require using tools that are not as accurate as doing the radius in a "front side" operation with conventional turning tooling. The 8" diameter makes it difficult to get a long enough tool behind the part and still maintain rigidity. Also, when this 8" diameter part comes off the remaining material blank, it will need a rather large catchers glove to grab it....... I don't know about you but I wouldn't feel safe trying this. Not to mention that it would still require another operation to remove the "nipple" precisely for the application.
2 set ups would be the way to go for a complete part but if they only need to do the radius end for a CMM to probe it, then just the radius would be sufficient.
So Bala, Does it sound real simple any more? There are a lot of things to consider when programming any machine and this is why we are called "Professionals".
MMMMMM, Dognuts....
Yeah, I know. It is kinda wierd that they are the breakfast of champions AND cops.....
