Fill counter bore with surface
PrototypeFred
Hello : I need to fill or cover a counter bore with a surface.
The surface that surrounds the counter bore is broken up into several surfaces.
Questions :
1)How do I go about filling this with a surface ?
2)And which of the surface commands should I use?
3)I am also trying to import this file or take a snapshot of this counter bore to put it in this post. I tried using the "Alt Print Screen " command , But I can't figure out how to do this.
Can anyone please help ???
I'm trying to use the gap control , but it does not seem to work like I want? The problem is the these counter bores are on the edge of the the part where there is a radius on this edge. I am getting too many "rapid retracts" because of the interruption.
That's why I need to fill these counter bore with a surface so when I go to machine this edge the transition is smooth.
Fred sent me an email so here is the deal. You can do this many many different ways. The easiest and quickest being Gap control. If you do not want the tool to dive in the hole, just remove the boundary from the surface at the floor of the cbore and check it with a small amount of stock. I also Netted and Cooned up the hole. This is more work than neccesary and also one more thing, if there is a tangency issue with the new surface the part will not be machined completely. This would be rare though. I deleted most of the part so the file is now very small. It would be good for all if you through this image and file up. You will most likely find other ways also.
Mike
