X4 MU1 Crash Regenerating Toolpath
Thee Rickster ™
I copied all the cutter paths from 1 machgrp/toolgp to another.
Rick, when you copy a toolpath from one group to
another, try this.
Use Edit Selected Operations/Change NC Filename
and edit the operation to match the new
Machine Group BEFORE doing any edits, geoemtry
selections or regens..
If you don't, the NCI file is still linked back to the
OLD Machine Group and that might be the cause
of some of these problems
  • Replies 266
  • Created
  • Last Reply
Top Posters In This Topic
Good Tip.
I believe the order i did it was as follows:
(my standard procedure)
-Create mac/group, tool/gp
-highlight pats in 1st group
-right click drag to new group
-repick mach/def
-pick new tool/gr with newly copied path/change NC
filename
-save
Start editing common and indiviual tool parameters
along with selecting new geo.
This is how I do copied paths from one group to another. I used to import right from the file
I'm working in. Either way it has always worked.
The x4Mu1 error is my nemesis.
[ 11-11-2009, 02:56 PM: Message edited by: Rickster ]
Rick,
re: Indexing
Is enabled by default during a Windows install.
1st;
My Computer -> right click local disk drive -> properties -> uncheck "allow indexing service to index this disk for faster searching" -> and let it do its thing. May take a while depending on the amount of data on the disk.
2nd;
Turn off Indexing service and prevent it from starting automatically at boot up.
Start -> Run -> services.msc
Scroll down and find the Indexing service. Stop it. Right click on it -> properties -> set startup type to disabled.
I also disable system restore from the system applet in the control panel. Then check to make sure the service is indeed off in the services console. That [insert four letter word for feces here] causes nothing but headaches and uses resources.
Rebooting didn't help now I am screwed
I a have been trying to make a path for 2 hours
and have had 5 crashes and no paths.
So now I am convinced they changed something
From X4 T X4 Mu1 that they either cant remember
what they did or there it is buried so deep
that they cant do anything about it
What ever it is I am getting nothing done today
and I might have to stop using X4 all together and
go back to X3 if THAT one doesn't start doing it.
X2Mr2, who knows.
maintenance....what does this actually mean????
Rick
Ok, this is funny. This is my 1000th post and I am here to report that I just got that crash on my mac's. frown.gif
Irony is not lost on this one...
Lost about 4 hours of work. I thought I had auto-save on but nope.
Go ahead and laugh. It's ok. I boasted about my mac's and they did the same thing. All on the count of 3 we commence laughter.
1..2..3....
DOHOHOHOHOHOHOHOHOHOHOHOHOHOHOHOHOHO!
ok.... ROFL hystericlly...
No.... j/k it sux for anyone to loose work...
But I swear I had an SIS chipset that wouldn't run Mastercam worth a crap...I think it and my Video driver had a conspiricy against me.... rolleyes.gifbiggrin.gif
Sure hope ya get it figured out Rick. I hate to see anyone having the aggravation you are having...
The best news I have is that I checked my permissions a an administrator account and it
seems that they are not as permissive as you might think.
earlier today i opened and old X2 Mr2 Sp1 (in ver X2)file and guess what
happened half way through my changes and regenning.
I got the error.
-dbl click my computer
-click tools /folder options and scroll to the bottom
-uncheck use simple file sharing
Then
-right click local C: drive/properties
-click the security tab
-click on your user name
-under allow all the boxes have to be checked
-if not click on full control then they all will
-hit apply and wait till done
then above the administrator user another
admin/your user name will appear and repeat
those steps to make sure you have full control
now when you right click any folder like your mcamx4 folder , hit properties/security you can click on each user name and all the (allow)full control boxes will be highlighted.
Before i did all this only some of the boxes wer checked under allow.
I formatted and setup windows and installed all my software with administrator permissions
and for some reason have less control then I thought
Check it all out ppl
once again so far so good
why did all this start with X4 MU1, i don't know.
I had CNC tech for a few hours sharing my desktop today, trying to sort stuff out.
I'll keep ya posted
Rick
Rick, when you installed, did you do so logged in as Administrator, or as you with admin rights?
I think that if rights are an issue, you would be better served to take ownership of the root of mcamx directory than to "just" assign permissions. That way, any future files and or directories created will assign full rights to you (owner).
MS permissions can be a little crazy, with assigned vs effective rights, and what is trickled down as files and folders are created.
I was sure I did it all as administrator, but I did
have a user name as myself, that I don't remember
creating. Either way i DID Have to allow the
permissions on both p.c.'s here at work and at home.
So far so good. I am designing for the day today
and I will be back at gramming a bit this afternoon
or tomorrow.
Peon, No. They just ask if it fixed the issue
which I won't anser untill a few week of grammin
and no error.
Rick
[ 11-17-2009, 10:22 AM: Message edited by: Rickster ]
