Help for open a pocket on a cylinder
David Colin
This is a common machining i have to do: To open a pocket on a cylinder. I would like to optimize toolpaths because stock isn't a box but cylinder. So if i use a standard 2d pocket function, tool is gonna loose too much time. I usually manage this with contour toolpath+2d pocket but i'm pretty sure there are better and quickier ways to make it. Probably with surfaces machining functions. Any advices ?
I uploaded a file on Cadcam FTP (Directory: MC9 / Filename: POCKET-OPENING.MC9)
Hi David
What Toolfab has suggested is the fastest & best way
I would like to add that instead of drilling u could ramp and then move the endmill around the edge.
That avoids the drilling cycle
I would recommend using a round insert bull cutter with a shank of a lesser diameter to avoid rubbing against the wall.
+1 to James.
I always draw a boundary that is a little bigger than the tool dia around my box or cylinder.
Then when you run a pocket on the 2-d lines, the tool will plunge OFF the workpiece.
Using a Zig-Zag path with the finish outer boundary unchecked and KEEP the tool down checked. Finish boundary after each pass.
Murlin
Hello all,
I am also having this problem
What about just drilling thru then sending an endmill around the edge and just dropping that chunk into the cavity.
That is what I do for small pockets. But what would you do if you had a 20"Ø pocket to open on the diameter of a 100"Ø cylinder?
Have a nice day,
David .
I can do it in a lot of ways .
If it is a through pocket the simplest way to do is a 3d contour .
It can be a problem if you are taking more then one cut ,because if you have fillets and pocket is angled ,keeping tangency draws to the tool jumping too deep in some places .
If it not a prob ,that`s the simplest way .
My part before a couple of days I did in this manner .
You can always also make the contour toolpath and project it on a cylinder .
the same for a pocket .
You can also make a regular poket and trim the toolpath after that too .
A bit dirty but works .
The best is to project ,IMHO
You want some example ?!?
Yes, this is fine for finish!
But what i really would like is to rough with constant z-depth (tool/material) and let Mcam to stop contours according to stock boundaries(surface cylinder).
A stuff we didn't talk here about opening pockets that way (contour and let middle part) is vibrations at the end of contour...
What i do is this cut through countour with offset value 2-3 mm and then finish like I showed .
BTW in project make faked pocket and point surface project operation to it and you will get nice pocket .
But the best is contour - less vibrations ,if you set your depth right (checked ) IMHO .
And very fast
The last cut enter deeper 3-5 millimeters with depth take off 1 mm and less RPM you will not have big vibrations .
I do it in steel with success always
You can leave on the contour tab like in wire EDm ,put MO ,broke all tabs by hand and make finish cut .All is possible .
But I prefer simple things ,I would go with contour ,and remember I run my machines ,I would never write something not good for me
Hi David, I've done a trim on your toolpath, it helps a little but I'd like to have some peoples help on 2 boundaries for trimming, has anyone succeed with 2 boundaries? Look at the file POCKET-OPENING-SIMON and try to select the 2 cyan (color 11) boundaries, would be nice if it'd work. HTH!
Simon
