All Activity
- Past hour
My mature wife and I both like sex . I had sex with my wife last night, and then we both watched Hard-core Mature sex of Sexy moms, mature and mature women. The scene where he licked her xxxx and she sucked his dick and hard-xxxxing is quite amazing. It made us incredibly horny and pushed me to learn some new sex poses and it makes me horny and hard. I usually watch these kind of videos at best porn cams by http://bestporncams.com/
- Today
yohip42167 joined the community
Nandakumar S joined the community
Does MCAM allow parametric drawings/models?
cncappsjames replied to Tinger's topic in Industrial Forum
In V8 it did. MoldPlus abandoned the project though and it never made it out of Beta. -
DeeDee joined the community
- Yesterday
VirtDB joined the community
Very cool, thank you so much. Before coming to the forum about this, I tried using Net but I kept getting a continuity error. Turns out I was chaining it wrong, most notably with the across curves. I chained the surface without making a radius, just to see what it would do and it gave me a continuity error, but still created the surface and it didn't look warped. I opted to use a radius as you did though, as I'd rather not get any errors at all. Cool trick, same with the draft example you showed me before with turning it into a spline. I really appreciate your help. Also for what it's worth, I was able to get fairly close to my desired motion with 3d blend, but as it came down the 45* wall it wanted to lift in some areas and plunge into the stock and with the angular lead-in/out control being limited, I could only avoid the plunge by giving it a combination of horizontal and big vertical lead-in. I also had to manipulate geometry a fair bit. This net surface with flowline is clean and simple. Thanks again.
ok so i got it working as you want see video here video
MachSim, CAMplete, Vericut // Cimco Probing, Productivity+
gcode replied to ikertx0's topic in Industrial Forum
Mastercam has rudimentary "AutoDif" in Verify. It's called Compare, and while it's not as powerful as AutoDif, it is quite usefull. -
When you get into high level contracting, your customers will demand that the files you deliver be run through Vericut. -
Mick replied to ikertx0's topic in Industrial Forum
My point exactly. -
#Rekd™ replied to ikertx0's topic in Industrial Forum
One crash on a high end machine will cost much more..... -
Well.... Consider it a form of programming QA/Insurance. You get what you pay for. Jus' sayin' -
In the truest sense, no.
Tinger started following Does MCAM allow parametric drawings/models?
Does Mastercam allow parametric designs?
Maheshkunart joined the community
MTW joined the community
Questions regarding Mastercamwire 2021
Mecspec posted a topic in Machining, Tools, Cutting & Probing
We have a question regarding how to use the stop function in Mastercam 2021 while programing a part. We havw tried all of thew options available, I think . We have spoken directly to our Mastercam distributor but the answer give nwas nclear and ineffective. -
Mecspec joined the community
crooks.joshr13 joined the community
Well dang, the method worked great for creating the surface, but the flowline doesn't "sweep" along, so the toolpath wants to make linear motion. I tried to reflow the surface, but it warps the surface. It's a bit cumbersome, but I think I'll have to offset copy the boundary curve to my desired stepovers, project the curves onto the surface, and use 3d contour. EDIT: Just kidding, that's not going to work either.
Really cool! Definitely not a method I knew of. Thanks! Would love to be able to do that, however I do not have the multiaxis package. Thank you for the effort though.
VERISURF TOOLS For MASTERCAM 2024
gcode replied to Verisurf - Ernie Husted's topic in Industrial Forum
I was able to see and fill out the form at my office. I've received a download link and downloaded the new version . I think my firewall at home was blocking the form's link. I'll check it this evening. Thanks!!!!! -
Stock model adds unwanted stock
Aaron Eberhard replied to MacGillicuddy's topic in Educational Forum
It's a known defect, just hit "save" and it'll go dirty, when you regenerate, it'll be fine.- 1 reply
- 1
- stock model
- educational
(and 1 more)
Tagged with:
I tried the download page in Chrome Firefox and Edge All three said "secure connection reset" - Last week
MacGillicuddy started following Stock model adds unwanted stock
I am playing around with stock model because the regular stock setup doesn't seem to allow me to have multiple pieces of stock. I found a tutorial that told me to create a block (solids tab) around the parts I want to machine and select them from the stock model command. I did this and it worked but it is including parts of my assembley as stock that I don't want as stock and in strange orientations. Any ideas as to what caused this or how I might fix it? The tutorial I followed is below if that is of any interest or help.
- 1 reply
- stock model
- educational
(and 1 more)
Tagged with:
Ali safi started following Mastercam 2017 Art Training Tutorial (PDF)
cncappsjames replied to ikertx0's topic in Industrial Forum
Depending on the options, I've seen it range from $20k to over $40k.. As far as being a freelancer, I know a number of high end contract guys that have made that investment. -
ikertx0 replied to ikertx0's topic in Industrial Forum
I have asked the price of Vericut and they told me that it costs 30k. It seems excessive to me, at least for a freelancer. I had the idea that the price would be around 10k -
ikertx0 replied to Verisurf - Ernie Husted's topic in Industrial Forum
sent form to wait for download and try verisurf -
Thank you, I have created some more stock model in half so that the load is not so much
I have to make a thread that I have never made before. This is a left hand acme thread 3 threads per inch. Must have 3 entries Can anyone help or teach me? Regards https://www.dropbox.com/scl/fi/rqz57ac68vegfbinuwxjs/Acme_Thread.mcam?rlkey=m65bsp5fjkre4tgm9k04qzwju&st=rc4hw7bq&dl=0
