All Activity
This stream auto-updates
  1. Past hour
  2. My mature wife and I both like sex . I had sex with my wife last night, and then we both watched Hard-core Mature sex of Sexy moms, mature and mature women. The scene where he licked her xxxx and she sucked his dick and hard-xxxxing is quite amazing. It made us incredibly horny and pushed me to learn some new sex poses and it makes me horny and hard. I usually watch these kind of videos at best porn cams by http://bestporncams.com/
  3. Today
  4. Maybe using Blend is better than Flowline, but the curve needs to be calculated... Flowline Blend
  5. In V8 it did. MoldPlus abandoned the project though and it never made it out of Beta.
  6. Yesterday
  7. Very cool, thank you so much. Before coming to the forum about this, I tried using Net but I kept getting a continuity error. Turns out I was chaining it wrong, most notably with the across curves. I chained the surface without making a radius, just to see what it would do and it gave me a continuity error, but still created the surface and it didn't look warped. I opted to use a radius as you did though, as I'd rather not get any errors at all. Cool trick, same with the draft example you showed me before with turning it into a spline. I really appreciate your help. Also for what it's worth, I was able to get fairly close to my desired motion with 3d blend, but as it came down the 45* wall it wanted to lift in some areas and plunge into the stock and with the angular lead-in/out control being limited, I could only avoid the plunge by giving it a combination of horizontal and big vertical lead-in. I also had to manipulate geometry a fair bit. This net surface with flowline is clean and simple. Thanks again.
  8. ok so i got it working as you want see video here video
  9. Mastercam has rudimentary "AutoDif" in Verify. It's called Compare, and while it's not as powerful as AutoDif, it is quite usefull.
  10. When you get into high level contracting, your customers will demand that the files you deliver be run through Vericut.
  11. One crash on a high end machine will cost much more.....
  12. Well.... Consider it a form of programming QA/Insurance. You get what you pay for. Jus' sayin'
  13. We have a question regarding how to use the stop function in Mastercam 2021 while programing a part. We havw tried all of thew options available, I think . We have spoken directly to our Mastercam distributor but the answer give nwas nclear and ineffective.
  14. Well dang, the method worked great for creating the surface, but the flowline doesn't "sweep" along, so the toolpath wants to make linear motion. I tried to reflow the surface, but it warps the surface. It's a bit cumbersome, but I think I'll have to offset copy the boundary curve to my desired stepovers, project the curves onto the surface, and use 3d contour. EDIT: Just kidding, that's not going to work either.
  15. Really cool! Definitely not a method I knew of. Thanks! Would love to be able to do that, however I do not have the multiaxis package. Thank you for the effort though.
  16. I was able to see and fill out the form at my office. I've received a download link and downloaded the new version . I think my firewall at home was blocking the form's link. I'll check it this evening. Thanks!!!!!
  17. It's a known defect, just hit "save" and it'll go dirty, when you regenerate, it'll be fine.
  18. I tried the download page in Chrome Firefox and Edge All three said "secure connection reset"
  19. Last week
  20. I am playing around with stock model because the regular stock setup doesn't seem to allow me to have multiple pieces of stock. I found a tutorial that told me to create a block (solids tab) around the parts I want to machine and select them from the stock model command. I did this and it worked but it is including parts of my assembley as stock that I don't want as stock and in strange orientations. Any ideas as to what caused this or how I might fix it? The tutorial I followed is below if that is of any interest or help.
  21. Depending on the options, I've seen it range from $20k to over $40k.. As far as being a freelancer, I know a number of high end contract guys that have made that investment.
  22. I have asked the price of Vericut and they told me that it costs 30k. It seems excessive to me, at least for a freelancer. I had the idea that the price would be around 10k
  23. Thank you, I have created some more stock model in half so that the load is not so much
  24. I have to make a thread that I have never made before. This is a left hand acme thread 3 threads per inch. Must have 3 entries Can anyone help or teach me? Regards https://www.dropbox.com/scl/fi/rqz57ac68vegfbinuwxjs/Acme_Thread.mcam?rlkey=m65bsp5fjkre4tgm9k04qzwju&st=rc4hw7bq&dl=0
  1. Load more activity
