machining copper
billystein
As a roughers I use 3 fluets hogs solid mills for alluminium ,for hog mill 12 mm S7500 f2500 z step 4 mm or s6000 f2000 take-off 6 mm ,bigger feed possible ,but my electrode holders will not stand it .
Also I like 3-4 flueted end mills end mills with coating for middle cuts and finish.
for end mill 3 mm S8000 (my maximum spindel speed ) f1500mm/min
z step 0.5 mm
For surfacing I use 3-4 fluets mills with extra-short fluet length with coating ball mill 6mm s7000 f2000 ,ball mill 1 mm s8000 f500 .
Try to use good tooling ,avoid radial bitting ,use a lot of coolant ,try to avoid using HSS mills .
If your relation length/diameter more then 10
do not be afraid to drop speed ,avoid shrieks in the corners .
I prefer Iscar coating IC900 and YG Xpower
For end mill 0.3 mm without coating S7850 f50 zstep 0.06 mm .
for big electrodes I use bull nose round corner insert mills from seco ,
for seco bull nose 25 mm radius of insert R6 2 inserts s7000 f7000 z step 0.7 mm
WTHH
Never machined copper, so I can't suggest anything.
One point to make, though: Make sure your wear eye protection. A copper speck will burn and hurt like hell. It will flare up if caught in your eye until removed.
I had an aluminum chip I needed a doctor to remove once. Thats when he told me to watch out for copper.
what grade? OFE or some alloy and is it dead soft or aged i.e. 1/4 or 1/2 hard.
dead soft is by far the worst it gets better with age...
when drilling take most of the releif out... or it will grab. I never use split points on copper.
as far as feeds and speeds, use about 75% of what you would use for aluminum.
I remember doing copper on a lathe, it was soft but without a good flood would stick to tn coated carbide no problem.
I agree with the zero rake drill bit no center relief. Much slower rpm than aluminum worked for me.
In a press I have sharpened round punches with 4 relief angles meeting in the middle, ejector pins didn't seem to help much. Again in a press plenty of lube. This particular material was half hard for an electrical bus duct.
Good luck!
We run quite a bit of copper. Try and use TIALN coated carbide whenever possible. I start at 500 sfm for a .5 dia. 2 flute cutter approx. .003 chip load or 23ipm feed. With drills I prefer 15 deg helix you can push them harder. Example .125 drill 9000 rpm 17 ipm feed. Much flood coolent.
