CHAINING PROFILE OF A PART. TRYING TO CREATE 1, CONTINUOUS CHAIN
honeybunches
I was some how able to manage this before but now all I am creating are multiple chains. I am using contour to profile a curved part. As I try to build the chain around the part, I get errors that the selected chain does not touch the branch point. If I select broken chains, it will create a new chain and start point.
Do I need to work on the wire of the part or is there a trick to easily create a continuous chain around the profile of a part? I am wondering if I have issues with my model and that is creating much of a problems. Wire looks good to me. Brought in in an STP file. No additional lines creates for the profile.
did you analyze chain?
sounds like you have a gap somewhere in the chain i have run into this before and the gap was like .0002 trim them together or connect the points then re analyze chain to see that it is 1 chain
A few options are available. Change all the entities in the chain to the same color, all entities that intersect the the chain to another color, then adjust the tolerance on the chain and use the color mask. 2d chain? Select c-plane prior to chaining. If some of the entities lay in a 3d plane or or fall on a slightly different plane, you can use xform translate to bring them all up to the same plane, then trim them if needed. HTH
Motorcity hit it.
Mastercam is asking if you're trying to go down the vertical line, or continue on along the profile. At the top of the chaining pop-up box, there's a button for "CPlane". You most likely have it on "3D".
Did you try the Create Boundary C-hook? This can give you a good result about 80% of the time.
Try this if you have a complicated part:
Do a Surface Finish Contour Toolpath.
Create an endmill that is .001 in diameter.
Set your Maximum step down to 20.0.
Set your depth limits to absolute.
Set the Minimum and Maximum depth to -.05 (or whatever depth you want the chain to be at).
In the advanced settings, set it to "Automatic", the top option.
Also, turn the filter on, ratio 1:1, and set the total tolerance value to .001. Also, turn on "create arcs in XY".
This will give you a single contour cut at the depth you specify.
Now go into backplot and choose "Save as geometry" and enter a level.
Just a little trick I've learned over the years. This will give you a nice, simple, filtered chain that is .0005 excess on your actual part.
I will look at some of these ideas tomorrow but I can tell you have tried 2D, 3D, Cplane, etc, all come up with the same error. I just wish I knew how I did it before. In a previous op, I chained the whole thing as one chain but I know I struggled before. Get to the point of just pushing buttons until something is close I guess.
I am really not sure if our model (step from Catia) is what causes issues or what but every part seems to have issues for us.
What we found yesterday is the chain is complete but there are several pieces of it and one was VERY hard to find. Serious zoom to get to it. Is there not an "easy" button to chain the entire profile? maybe an easier way to chain around parts rather than selecting the 50 some chains that make up the perimeter?
Catia to step to Mastercam has always resulted
in troublesome models for me.
Sometimes Solidworks converts them better,
sometime Mastercam does a beter job.
Try the chook FindOverlap.
It is pretty good for finding and fixing overlapping enities in wireframe
also
Analyize/chain can find and fix many errors
Use window chaining to select really dirty chains.
and
as a last resort crank up your chaining tolerance
The default setting is .0002, try bumping it to
.001 This will allow chaining to "jump" small
gaps that may be dificult to find
Instead of spending all the time trying to clean up a dirty set of wireframe, my method gives you a single chain with no branch points in about 2 minutes.
I used to do the whole, delete duplicates, find overlap, analyze chain, adjust chaining tolerance dance.
On most solids it really isn't an issue. It is the bad models you get, either a bad solid, or a set of surfaces that is awful that really cause you headaches.
Another thing you should probably check: Is the "create edge curves" checkbox turned on in the "options" dialog box?
If the model you are importing already has wireframe in it, this button will cause Mastercam to generate a second set of edge curves on the model. This can cause some serious problems when you are trying to separate the wireframe you want to use for toolpaths.
HTH,
If your geometry is "clean," (trimmed, no branch points, no overlapping entities, etc), it's a one click operation.
Thad
Will "sihouette boundary" chook work for it?
It might work in a very simple part but usually gives very rough chain that only loosely follows the part profile. It is meant to do toolpath boundaries only. It would be very powerful tool in chaining also if it worked more accurately.
On top of some of the suggestions already mentioned, I also occasionally use this method.
Xform - Project - 1.00 (copy)
Put the result on a different lvl then run overlap chook with delete duplicates.
