From CNC - Why X6 downloads have been suspended
People
if you want to understand why ( I can be cranky) and why I may have issues that you may not ever see,
this is my everyday daily gramming routine
My molds are not exactly simple.
This is an example of a portion of one component (cavity).
This is perfect example of a 300 to 500meg file(ill get you the exact size tomorrow)
1, 2 and 3 deg tapered walls, many different size fillets and rads
So its smallest cutter is finished with a 1/16 x 1° die-sink 2-1/2" long
my cutting strategy for this tool is like this.
-1" index em/ 1/2" ball .......rough and rest rough for semi-finish
-1/4" ball rest waterline then water line (with added cuts) - then scollop and horizontal flats and rib tops .......finish
-1/8 1 deg die-sink ball rest waterline (finish ) .008" step-down zig-zag -then .006 pencil cut using(limit # offsets to 9, ref tool 1/4", over thick .01).......finish
-1/16 1 deg die-sink ball rest waterline (finish ) .005" step-down zig-zag -then .004 pencil cut using (limit # offsets to 6, ref tool 1/8", over thick .01)....... all finish cutters have a 0.0005" total tolerance
core, cavity, 2 slides, core insert ,cavity insert....
any EC's result in reselect new or partial new geo and re gen.
I regen all the non rest paths first, save an then do one rest at a time, be cause of the issue at hand.
Now this is just for EC's that are a few times a month.
I take a new tool file like this one. and have to create recut standalone inserts(graphite mold process)
to recut the cavity after it deteriorates from pouring. cor inserts are usually stand alone(off the hop) if the parting line is basic,flat.
recut insert for a cor base if the part line is contoured and or stepped etc. out of the original block
I do many of these a month (5 to 10) while working on new tools.
so i copy the cavity paths to a new machine/ tool group for the cavity recut
insert the finish modeling the insert and reselect
and regen. same goes with any core standalone recut inserts
Now you can understand how important to get these paths to
regen the first try at it., when you are as busy a programmer as me.
I do an average of 2 new molds a week and 1 or two recut inserts a week
I so most of my forum posting while my p.c. is crunching long paths
and simultaneously designing mold in another instance of MC.
People
Your job description is the same as mine exactly! I feel your pain.....daily
  • 2 weeks later...
