Posting 2 different B0 machining operations, no rotation commands.
JB7280
Is it possible to make Mastercam post B rotations, even though both toolpaths are at B0., but different work offsets?  I have 2 fixtures, with slightly different B work offsets, so I want to unlock the pallet, rotate, and lock.  But when I post these, it seems like Mastercam just sees B0, and doesn't try to rotate.
Unfortunately I can't post a file, but I could quickly make a sample file, if I'm not making sense.
I've run into the same thing before. My workaround was using a manual entry with: rotary unlock, new offset B0, rotary lock. I'm sure you could make this happen automatically with the post but I haven't had the time to play with it.
You could probably accomplish the same thing with a force tool change, tho this would probably add unnecessary motion.
I'm also interested if there is a better way.
Without having a copy of the file I can't recommend a good solution
I would just post a  dummy drill cycle at a different B location that punches a hole in a safe place in the sky.
After posting, just delete the dummy drilling toolpath and you are good to go
Can't you tell it if wcs changes re issue position command?
I did this with my probe cycle on the 5 axis. Instead of using force tool change of the wcs changes it zeros z and re issues unlock and positioning moves with the new offset
ptlchg0$         #Call from NCI null tool change (tool number repeats)
      pcuttype
      pcom_moveb
      pcheckaxis
      c_mmlt$ #Multiple tool subprogram call
      comment$
      #pcan
      result = newfs(15, feed)  #Reset the output format for 'feed'
      pbld, n$, sgplane, e$
      pspindchng
      if sopcomm <> sblank,
        sopen_prn, sopcomm, sclose_prn, e$
      sopcomm = sblank
      if prb_flg = 1,   #WCS CHANGE FOR  PROBE
      [if workofs$ <> prv_workofs$,
        sav_absinc = absinc$
        absinc$ = zero
        pbld, n$,"(WCS CHANGE RETURN Z TO ZERO)", e$
        pbld, n$, *sgabsinc, *sgcode, sg49, "G53","Z0",e$
        pbld, n$,"M132",e$
        pbld, n$, *sgabsinc, *sgcode,  pwcs, pfcout, e$
        pbld, n$,"M131",e$
        pbld, n$, sg43, *tlngno$, e$
        pbld, n$,"(PROTECTED POSITIONING X AND Y)" ,e$
        pbld, n$,"G65 P9510",pfxout, pfyout,e$
        pbld, n$,"(PROTECTED POSITIONING Z)" ,e$
        pbld, n$,"G65 P9510", pfzout,e$
        pe_inc_calc
        ps_inc_calc
        absinc$ = sav_absinc
2 hours ago, crazy^millman said:
With rotated planes and a correctly configure post then it should output the rotations you want. Really a couple different ways to control this. Can you make a dummy file with a couple toolpaths to use as example.
That's the issue Ron, I think.  The planes aren't technically rotated, but they are different work offsets.   I'll make a dummy file in a moment.
I would like for it to post Z retract, Rotary Unlock, B positioning move, and Rotary lock after the N2 line.   To correct for "fixture error"  I feel crazy, because people, including Mastercam Tech Support seem to think I'm doing something wild, lol.  But I am 100% certain I've done this fairly simply in other CAM softwares.
I did something similar, temporarily, but the powers that be (aka management) likes to have files that post out, 100% ready to run.
https://drive.google.com/file/d/1iUOKIpRsN_3lvTRoej_nlYAyfBDuc1ot/view?usp=sharing
Are the two B0 offsets always the same relative to one another?
I would consider the first as B0 and the second as B6 (or whatever) and when they share a WCS, you know it will rotate between them.
Also on my horz, I need to force a tool change in between rotations for the same tool, or it will skip over the B call - might try that out. You'll be certain to get a retract then as well.
In CAM, yes, they're the same.  In the machine, they're slightly different from each other.  So I need it to correct when going between the two offsets.  But yea, I'll probably do a force tool change for now, unfortunately.
11 minutes ago, JParis said:
I built a whole section of logic that handles this for me...I have a jump height set in the MR's....on any offset change or rotation I output the jump height...
No "Force Tool Change" required.
Haha, I have no idea what that means, but I assumed something like that is what's necessary, which is beyond my knowledge level.  Might have to get a post made for this.
i used an mpmaster i had
i changed this
search for and uncomment this line
#           sav_rot_on_x = rot_on_x    #Uncomment this line to output rotary axis value even when it's not used
then at the end of ptlchg0$ i added a pfcout on that line
 was this
          else,
            pbld, n$, sgabsinc, [if not(index), pwcs], pfxout, pfyout, pfzout, pcout, e$
i changed to
          else,
            pbld, n$, sgabsinc, [if not(index), pwcs], pfcout, pfxout, pfyout, pfzout, pcout, e$
gave me this output
N5 G00 G17 G20 G40 G80 G90
N10 G91 G28 Z0.
N15 (COMPENSATION TYPE - COMPUTER)
N20 T239 M06 ( 1/2 FLAT ENDMILL)
N25 (MAX - Z.25)
N30 (MIN - Z0.)
N35 G00 G17 G90 G54 B0. X-.25 Y.5 S1069 M03
N40 G43 H239 Z.25
N45 Z.2
N50 G94 G01 Z0. F6.42
N55 X-.75
N60 G03 X-1.25 Y0. I0. J-.5
N65 X1.25 I1.25 J0.
N70 X-1.25 I-1.25 J0.
N75 X-.75 Y-.5 I.5 J0.
N80 G01 X-.25
N85 Z.2
N90 G00 Z.25
N95 G55 B0. X-.25 Y.5 Z.25
N100 Z.2
N105 G01 Z0.
N110 X-.75
N115 G03 X-1.25 Y0. I0. J-.5
N120 X1.25 I1.25 J0.
N125 X-1.25 I-1.25 J0.
N130 X-.75 Y-.5 I.5 J0.
N135 G01 X-.25
N140 Z.2
N145 G00 Z.25
N150 M05
N155 G91 G28 Z0.
N160 G28 Y0. B0
i changed this
 was this
          else,
i changed to
          else,
gave me this output
N10 G91 G28 Z0.
N25 (MAX - Z.25)
N30 (MIN - Z0.)
N40 G43 H239 Z.25
N45 Z.2
N55 X-.75
N65 X1.25 I1.25 J0.
N80 G01 X-.25
N85 Z.2
N90 G00 Z.25
N100 Z.2
N105 G01 Z0.
N110 X-.75
N135 G01 X-.25
N140 Z.2
N145 G00 Z.25
N150 M05
N155 G91 G28 Z0.
N160 G28 Y0. B0
Close, and gives me some hope.   I need retract, and unclamp/clamp comments.   I wish I knew more about editing posts.  But that's hopeful at least.
  • 2 months later...
I have a pstopcomment segment that I use for part clamping/unclamping, inverting material, adding cap screws, ect and use variables to pick the particular code that I need. You just pick the mi7$ choice
pstopcomment     #pallet rotation macro
      "G91", "G30", "X0", "Y0", "Z0", e$
      if machine = 300 | machine = 800, *sunlock, "(PALLET UNLOCK)", e$
      "G91", "G28", "B0", e$
      "M60", e$
      if mi7$ = 1, "M00", "(ADD CAP SCREWS THEN REMOVE CLAMP)", e$
      if mi7$ = 2, "M00", "(REMOVE WASTE MATERIAL)", e$
      if mi7$ = 3, "M00", "(RESET PART TO POSITION 2)", e$
      if mi7$ = 4, "M00", "(MOVE CLAMP TO BOTTOM POSITION)", e$
      if mi7$ = 5, "M00", "(ADD CENTER CLAMPS TO PALLET A)", e$
      if mi7$ = 6, "M00", "(UNCLAMP AND RECLAMP PARTS)", e$
      if mi7$ = 7, "M00", "(ADD CLAMP)", e$
      if mi7$ = 8, "M00", "(ADD CAP SCREWS)", e$
      if mi7$ = 9, "M00", "(ADD CLAMPS)", e$
      if mi7$ = 10, "M00", "(INVERT PARTS PER SETUP SHEET)", e$
      if mi7$ = 11, "M00", "(ADD CLAMP THEN REMOVE CAP SCREWS)", e$
      if mi7$ = 12, "M00", "(ADD OP1-2 CLAMPS THEN REMOVE OP1-1 CLAMPS)", e$
      if mi7$ = 13, "M00", "(REMOVE ANTI-VIBRATION BLOCKS)", e$
      if mi7$ = 14, "M00", "(REMOVE CENTER SCREWS THEN ADD CLAMP)", e$
      if mi7$ = 15, "M00",
        "(ADJUST CASTED SLEEVE WITH 1.97 DIA SHAFT THEN REMOVE)", e$
      if mi7$ = 16, "M00", "(ADD THEN REMOVE CLAMPS PER S/U SHEET)", e$
      if mi7$ = 17, "M00", "(ADD CAP SCREWS THEN REMOVE Y STOP BLOCKS)", e$
      if mi7$ = 18, "M00", "(CLEAN AND DEBURR PART BEFORE PROBING)", e$
      if mi7$ = 19, "M00", "(REMOVE CLAMP)", e$
      if mi7$ = 20, "M00", "(REMOVE CLAMPS)", e$
      if mi7$ = 21, "M00", "(REMOVE ANTI-VIBRATION BLOCK)", e$
      if mi7$ = 22, "M00", "(DEBURR HOLES AND EDGES BEFORE FINISH CUT)", e$
      if mi7$ = 23, "M00", "(CLEAN OUT HOLES WITH DRILLS)", e$
      if mi7$ = 24, "M00", "(ADD CAP SCREWS AND INSPECT Z LOCATION)", e$
      if mi7$ = 25, "M00", "(ADD CAP SCREWS AND INSPECT FOR FULL CLEANUP)", e$
      if mi7$ = 26, "M00", "(ADD CAP SCREWS THEN REMOVE ALL CLAMPS)", e$
      if mi7$ = 27, "M00", "(ADD CLAMPS THEN REMOVE CAP SCREWS)", e$
      if mi7$ = 28, "M00", "(ROTATE PART PER SETUP SHEET)", e$
      if mi7$ = 29, "M00", "(ADD FLAT HEAD SCREWS AND REMOVE CLAMPS)", e$
      if mi7$ = 30, "M00", "(ADD FLAT HEAD SCREWS)", e$
      if mi7$ = 31, "M00", "(CHECK 28.084 DISTANCE AND 2.00 DIAMETER)", e$
      "M60", e$
       if machine = 300 | machine = 800, *slock, "(PALLET LOCK)", e$
      " ", e$
Note, this segment is the way that we modify our clamping and any use of this
code is the user's responsibility to make sure no crashes occur.
We've been using this segment for at least 20 years on 12 horizontal machines, (5 different makes).
