Roll tapping titanium
machinedudester
Does anyone have any experience roll tapping titanium. We have parts made from TiGALV4 and they are trying to roll tap them 9/16"-18 UNJ 3B and the titanium keeps sticking to the tap after the first hole and then the no go starts to go and the threads get rough. They used an oversized drill (.5394") and moly-dee and it became very hot. Any advise would be greatly appreciated, thanks. headscratch.gif
Tap drill is definitely a little big so that's not a problem. A form tap that big is going to require some torque so I hope the machine has some sack, though that doesn't sound like the problem either here. We typically use OSG Exo-TAP [NOT HyPro] NRT form taps in tough materials.
Threadmilling is DEFINITELY the way to go. Threadmilled 2-56 blind holes up to .210" deep. Singlepoint 10,000 RPM, 1.5 IPM, ONE pass. Works like a charm. I would never do it any other way.
Hey, thanks all for the information provided so far. This is an aerospace application & thus the tread call out is per AS 8879 "Controlled Root radius" Class 3B So no chance of cutting as MUCH as I'd like to go that route.
The machine we are using is the Haas VF3 4-axis CNC, 40”x20”x25”. I don't think Sack (as someone put it) is an issue wink.gif Also we tried a steam oxide coated tap from Balax the first time which is a porous coating for holding coolant. Balax rep then suggested a ti-lax coating which was non porous on the second run. BOTH of which seemed to hold on to the Ti. Thanks for the lubrication suggestions also. Do you think I should be worried about heat as when forming? I can tell you it was a LOT without using coolant.
As far as I know, the main deal with the AS 8879 is that you need a "controlled root radius" at the root of the external thread only. The only difference on the internal thread is that the minor dia must be increased to clear the modified root radius. It would be a good idea to just purchase the download of the current spec. I think it is available on sae.org. There is also a spec that I can't think of at this very minute that is used in Aerospace quite often that states that you can't use a Form tap. You may want to watch for that.
Mike
You can actually control the thread form and size with a threadmill whereas with a tap (roll or cut) you cannot.
I still say threadmill REGARDLESS unless there is a specific prohibition on a cut thread.
  • 14 years later...
Sooo, I have to tap with M8x1.25 STI for helicoil inserts. I asked one of the dealer closer to my location and he suggested to use EXo-Form Tap from OSG.
OSG 1636000708                             We have Ridgid high performance thread cutting fluid.
I have DMU from DMG Mori 5 axis machine. Should I try? or leave aside form taps at all and start looking only and only thread cutter options?
  • 3 weeks later...
1 hour ago, Leon82 said:
What speed do you use. We want to try it on some 00-90 threads
Speed is one part of the equation. Synchronization of the spindle to the feed rate is the real issue. Need to think about using the Emuge Floating holder and that will make the process more successful. Ream the holes before roll tapping them to provide the most stable surface to allow the molecules the shape and preform needed to make this work. Drill is still be nature a ripping action into the Material and even a triple margin drill is nothing compared to a reamer at providing the base base surface for roll forming holes in any ferrous based material.
Link:
That said I might start at 2000 rpms with a G95 feed. That woulds be .0111 per revolution or 22.2222 ipm feed rate.
  • Like 4
I like the idea of the reamer.
I'm still trying to convince the powers-that-be to buy at least a couple of those micro float tension-compression holders, but they still think putting taps in standard ER collets and holders is good enough.
