What kind of machines??
  • Replies 73
  • Created
  • Last Reply
Top Posters In This Topic
Rocketmachinist,
How is the VM3? We may be looking at a VM2. Any major concerns we should be aware of? We were looking at adding the 40 tool changer and thru coolant (300 psi). Actually, thru spindle coolant would be new to us. Is the 1000 psi thru coolant something we should look at? What would warrant upgrading to the 1000 psi?
I was reading this the other day, and figured i would make myself a list of cnc's.
Off the top of my head.......
LATHES
Okuma
3 LB-25’S
6 LB-35’S
1 LB-45
1 LB-45M
1 LR-25
1 LU400
1 LU400M
1 L470M
Mori Seiki
2 SL-35’s
MILLS
Okuma
1 MA-60HB
1 MA-600HB
1 MC-4020
2 MA-650VB
1 MC-5VA
1 OLD CADET
1 M460VE
4 MC-4VA
MAKINO
2 V56’S
1 V55
1 V33
1 GF6
1 F5
That's just what's in this building. Minus the edm and grind dept.'s.
:DB):p
Well after seeing this list of machines I can see everyone is in a different league than me lol. But I can at least say I own them free and clear which helps from a buisness standpoint.
(1) Fadal VMC totally rebuilt from the ground up.
(1) Haas bought brand new in 2009
(1) Seat of Mastercam had to throw this in the list as this is just as important as any machine I have in my shop.
Milling
(2) Mazak VARIAXIS 730-5X II
(4) Mazak VARIAXIS 630-5X II
(2) Mazak VARIAXIS 500-5X II
(5) Mazak VMC Nexus 510C-HS
(2) Mazak VMC Nexus 510C
(1) Mazak HCN 4000-II Horizontal
(1) Mazak VTC-300C
(1) Mazak VTC-41M
(1) Daewoo VMC Diamond Series DM 50/25
(1) Daewoo VMC Diamond Series DM 40/20
(1) HAAS VMC - VR11 5-Axis Tilt/Tilt
(1) HAAS VMC - VR8 5-Axis Tilt/Tilt
(2) HAAS VMC - VF9 + TR-310 Trunnion = 5-Axis
(1) HAAS VMC - VF7 + TR-210 Trunnion = 5-Axis
(1) HAAS VMC - VF5-50 Taper + TR-210 Trunnion = 5-Axis
(2) HAAS VMX - VF4 + TR-160 Trunion = 5-Axis
(1) HAAS VMC - VF3 + HRT-210 Rotary Inidexer = 4-Axis
(2) HAAS Super Mini-Mill
(1) HAAS EC-400 HMC = 4-Axis
(1) HAAS EC-500 HMC = 4-Axis
(1) Bridgeport VMC1000XP2
(1) Bridgeport VMC 1000, DX-32
(1) Cincinnati Milacron Arrow 2
(1) Kitamura MyCenter 2x
(2) Fanuc Robodrill T10
(1) Bullard CNC 4 Axis Horizontal Boring + Rotab
(1) HAAS GR510 Gantry Router
(1) HAAS GR512 Gantry Router
(1) Comal CMS MC6000 - 3D CAD/CAM Int. Extrusion Milling Center
TURNING
(1) Mazak Slant Turn - ST-50N
(1) Mazak Nexus QTN-250 - IIM
(1) Daewoo Puma 250 MS
(1) Daewoo Lynx 210
(2) Doosan Puma 240M
(1) Daewoo P240A
(1) Milltronics ML22-80
(1) Hitachi Seiki -Hitec 20SII
(1) Schiess Aktirngesellschaft VTL 1400MM Swing
EDM
(1) Fanuc EDM Model aOiA
(1) Fanuc EDM Model a0iC w/180iS-WB
(1) Fanuc EDM Model a-1iC w/180iS-WB Controller
(1) Fanuc HM400T HoleMaster
Waterjet
(1) Omax 2652 Integrated CAD/CAM
(2) Omax 80160 Integrated CAD/CAM
Well update on our VM3.
We got the machine setup and working.... For a little while. Every other day I get an error 234 Spindle encoder cable fault. Everyone thinks that it's a connector that came loose during shipping. The downside is we bought the machine through a dealer that works with the federal govt. So to get a technician out here we have to get that company (which is in Maryland) to call up a repair company (in Washington) to fly out a guy to fix the machine. But, if we would have bought the machine through our local dealer Selway, then it would be a 20 minute drive for the technician to fix our machine. If we would have known it was going to be this much hassle we would have bought locally and been done with it.
Yikes! We got ours thru Selway
Yea, the guy came out yesterday and replaced the encoder and the encoder cable. I'm running another spindle break-in just to get some time on the machine and make sure it doesn't do it again. But the technician was messing around with the wire and the encoder and got the machine to error out when wiggling the connection. So we look in good shape.
Milling:
[2] Okuma ES-V3016, OSP-U10M
[1] Mori-Seiki SV-403, Fanuc 18
[1] Okuma-Howa Millac 438V, Fanuc 18
[1] Matsuura RA-II, Yasnac MX3
[1] Matsuura V.Plus-550, Fanuc 30
Turning:
[4] Okuma LB3000EX, OSP-P200L
[2] Okuma LB3000EX-MY, OSP-P200LA
[6] Okuma Captain L370, OSP-E100L
[3.5] Okuma Cadet LNC8, OSP-5020L
[1] Okuma LT-15M, OSP-U100L
[1] Hardinge T51SP, Fanuc 18
[1] Hardinge T42SP, Fanuc 18
[1] Mori-Seiki SL4, Yasnac 2000-G2
[1] Mori-Seiki SL204SMC, Mitsubishi Meldas
[1] Okuma-Howa ACT-4, Fanuc 10T
Gear making is top secret, sorry
I wonder if the feds were gonna let Bubba get to know (in the biblical sense) Gene and that's why he gave that dealer exclusive Government facilities special deals.
"Gene, you can take it in the wallet, or you can take it in the @$$... You choose"
  • 4 months later...
New update :thumbsup:
(20) Mori Seiki Vert. Machining Centers, 3 and 4 axis, 40 and 50 taper, 20” x 45” max.
(26) Mazak & OKK Vert. Machining Centers, 3 and 4 axis, 40 and 50 taper, 30” x 80” max.
(5) OKK & Kiwa, Horz. Mach. Ctrs, dual 500 mm pallets, 4-axis, 40 taper, 28” x 28” max.
(4) Mazak, Horz. Mach. Ctrs, dual 500 mm pallets, 4-axis, 50 taper, 31” x 31” max.
(15) Mori Seiki CNC Mill/Turn Lathes, sub-spindles, Y-axis, 13” dia x 48” long.
(5) Mori Seiki & Johnford CNC Lathes, 2 axis, 28” dia x 36” long.
(4) Okuma Howa & Doosan CNC Vertical Lathes, 46” dia. max. x 28” long.
(8) Mazak Integrex 5-axis mill/turn centers, 23” dia. max. x 60” long.
(4) Studer & Kellenberger CNC ID/OD Grinders, 16”dia x 40” long max.
(18) Blohm, Abba & Magerle 3-axis Creep Feed Grinders, 24” x 8” wheel max size, 100 HP.
(15) Campbell, Blohm & Haas 5-axis CNC Grinders, 25” x 25” max.
(7) Mitsubishi, 5-axis wire EDM, 14” x 20” max.
(25) Mitsubishi & EDM Solutions, EDM sinkers, 16” x 30” max.
(10) Beaumont, Current & Belmont EDM 5-axis hole drillers. 14” x 14” max.
INSPECTION EQUIPMENT:
(22) CMM machines, Brown & Sharp, LK and Global, (7) floor CMM’s. Scanning Capability.
(15) Optical Comparators. 30” screen x 50x magnification.
(6) NDT Unlimited FPI, MagWorks MPI & Habco Air Flow Systems
SOFTWARE:
CATIA, Unigraphics NX6, Solidworks, Matercam, Surfcam.
MILLING
1 Mazak F.H. 8800/ON 20 PalleT sys WITH
1 Mazak E 1060 5Axis
4 Mazak FH-4800/ 36 Pallet Palletech sys
4 Mazak PFH-5800/ 64 Pallet Palletech sys
2 Mazak VTC 300
1 Fadal VMC 40x20
1 Nexus 510c-II
1 Nexus 410A
2 Variaxis 630 5Axis/ 24 pallets
TURNING
1 Fanuc Robot feeding
Mazak Integrex
(1) 200 IV ST
(1) 200 III ST
1 Fanuc Robot M-20 IA feeding
(2) Integrex 100 IV ST
1 Gainty Robot
Mazak Mutiplex 8200Y(1)
2 Mazak Integrex 300-IV ST
2 Mazak Integrex 200-III T
4 Mazak Integrex 200- IV ST
3 Mazak Integrex 100-IV ST
2 Mazak Nexus 100- II M
Bar Feeder
2 Mazak Integrex 410H
1 Mazak Multiplex 6200Y
Bar Feeder
1 SQT-250 MY
1 Mazak Quick Turn 6"
Bar Feeder
1 Mazak Nexus 200 8"
1 Mazak Quick Turn Nexus 350
GRINDING
1 Cincinnati Cylindrical Grinder
1 Chevalier Accugrind 18 x 6
MILLING
2 Mazak VTC 300
1 Fadal VMC 40x20
1 Nexus 510c-II
1 Nexus 410A
TURNING
Mazak Integrex
(1) 200 IV ST
(1) 200 III ST
1 Gainty Robot
Bar Feeder
Bar Feeder
1 SQT-250 MY
Bar Feeder
GRINDING
Little?
