Test File For PC 'Puting
Trevor Bailey
What does this test really prove? Hard drive or RAM capabilities? What part does the video card play in the processing time? Do the allocation setting come in to play with this? Just asking, because my computer is running really slow. I ran almost three minutes on this test. I know my computer is out of date...800MHz 512MB Nvidia Gforce...but I would still like to get the best performance out of it till I get a new one.
  • Replies 114
  • Created
  • Last Reply
Top Posters In This Topic
Well if you compare your numbers with a comparable system, you should have roughly the same crunch times.
Video plays a part in processing time because time to display does play a part in completion time. If you have "Display Surface Plane Intersections" active (default setting) then video will play an even greater role in how fast it crunches.
I have a PIII-800 at home. I'll run the test on it and post the results...
  • 1 year later...
HP Pavillion zd7000 Laptop
P-IV 3.4GHz W/ HT
1GB RAM - 512MB Allocated to MC
NVidia GeForce FX Go5200 64MB
XP Pro O/S
V9.1 MR0105
1st - 60 Sec.
2nd - 25 Sec.
X MR1 RC Beta on same computer.
1st Time 40 Sec.
2nd Time 15 Sec.
Not bad. Definitely a speed advantage to X.
  • 1 year later...
Athlon FX-60 at 2.8ghz
Vista x64
X2-MR1
4 gigs ram
with eye-candy turned on:
1st time - 45 seconds
2nd time - 23 seconds
with eye-candy turned off:
1st time - 41 seconds
2nd time - 20 seconds
Same box - under XP PRO x64
1st time - 39 seconds
2nd time - 19 seconds
with Ramdrive PRO from www.superspeed.com
1st time - 22 seconds
2nd time - 15 seconds
No ramdisk at this time for Vista x64 or x32 - staying at XP for majority of time. (I am running dual-boot system at this time)
1st 34 sec
2nd 14 sec
XP PRO
RAM Saver Pro
Asus SLI Deluxe
AMD 3500+
2Gig RAM
SATA Raid HD
SLI Mode on
(2) NV GeForce 6600 GT
I think this test is misleading as it doesn't really work the PC like a smaller stepover and Tighter tolerances would( I think some of the higher end PCs here would show a much larger gap on a more cpu taxing test). I have noticed the processing times seem to increase exponentially the more Toolpaths in a file and the fact that the second time is allways faster leads me to believe that memory is being tied up each time a Toolpath is generated eventually to the point in which time is spent freeing memory while processing.
Glad to see my 2yr old box is still competetive though.
Troy
