Benchmark
Roger Peterson
He says this (mcam) won't take advantage of a Tesla cuda-based machine. Too bad.
What have I been saying this whole time! Abandon the cpu and move it to GPU. CUDA or OpenCL!!! But what do I know about computers :rollseyes:
cnc software, if you want to make mastercam fast, look into CUDA based threading or Open CL based. Then we could take advantage of tesla/fermi as computing cards or just use the ones we have in our comps!
Hi all!
I found an easy way to significantly improve calculation times on i7. My original time was around 1:30 with my i7 model 920, but I was able to get 1:13 by changing the default BCLK (aka. base frequency) from 133 MHz to 200 MHz. As I understand it, this one setting affects memory, CPU and BUS speeds. Basically my processor went from 2,7 GHz to 4,2 GHz.
These setting are machine specific, so you need to google or test the right setting. And of course you can get even more by changing voltages etc, but that is more complicated and it easier to break something. When I tried with custom voltages etc, it toke over two minutes to complete.
We tried this on Reijo’s i7, which is model 860, and there 180 MHz was too much. We settled for 150 MHz, even though it probably could take more. The original time was 1:48 and with the change, it was 1:32.
Some motherboards, like mine X58M, have this ability to test the highest setting automatically. In my case, it didn’t work, but it should be the safest way, so you should at least try it.
Here’s my hardware:
Intel i7 920 over clocked to 4.2 GHz
MSi X58M board
6144 MB of DDR3 memory
NVIDIA Quadro FX 1800
Windows 7 64-bit
I also changed the Affinity settings from the task manager, since for some reason, the default for Mastercam in my system is only one core. With only one selected, it calculates 50% slower, since it using, one core. So by clicking the Mastercam.exe, from the process-menu, with my right mouse button, I can get to the affinity settings. There I can choose that Mastercam.exe can use all cores.
Edit:
I would also like to add, that the multi-threading didn't make any differense to the calculations. The time was the same.
As I understand it, my i7 doesn't have a temperature meter. The temperature is calculated from voltages and some other integers. When the calculated value reaches 100, the processor starts to drop the multiplier to slow down the processor and keep the calculated value under 100.
In my tests, this really hapens. After several minutes off full load, the temperature integer value get's to 100, and the multiplier drops.
But a better cooler could not hurt.
My T3500 came in today, and the benchmark was the first thing on my to do list.
I spoke with Mike Debutts earlier this week about a Solidbox system, but I couldn't wait 3 weeks for a new box.
My laptop finally bought the farm, and as you can see, I have a stack of new jobs and rev changes on my desk. There are 2 more stacks that go with that one.
I found this on the Dell refurb site for $2500 with the monitors included.
Dell Precision T3500
Xeon W3570 3.2Ghz 8M L3 6.4Gts
4 Gb ECC DDR3 @ 1333 Mhz
768 Mb Nvidia Quadro FX1800
300 Gb 10,000 rpm Velociraptor 16Mb Cache
Windows 7 Professional 64 bit
Dual P2210 22" Widescreen Monitors
SpacePilot Pro
So far I love it.
I'll bump the memory to 12 Gigs and add a second Velociraptor in a couple months and benchmark it again.
Meh new box:
Respectable time for a $2500 setup.
I just installed my second Velociraptor today and set up raid 0 through the Matrix onboard raid control and only see a second or two gain in the benchmark.
Everything says that the array is working properly, but in windows disk management, it is still recognized as a simple volume, not a dynamic or striped volume. I'm guessing that's because the raid array is controlled by the bios.
5 min. 38 sec.
IBM Intellistation M Pro (desktop)
Pent. 4 @ 3.2 GHz
2GB Ram @ 800 MHz
Windows XP Pro
Total tolerance all 3 ops set to .0001
I was very surprised at how fast this processed so I ran it again, 1st with differeent tolerance, then again with .0001 tolerance...same result as before 5 min. 39 sec.
