Choppy Contour - PLEASE HELP
dwmartin
dwmartin,
I've ran into this situation several times with importing models. If the toolpath is a true contor, try Create - Curve - Slice then pick the surface at which you want the slice to be made through. You must provide a Z plane deeper than the top of the surface to create the curve properly, I'd suggest using a different color than the base geometry for visual purposes. Once the curve has been generated use it for the countour chain geometry and see if that helps. It usually works for me.
Josh
  • 2 weeks later...
I'am having a similar problem. I just did a fresh install of X3. I created an elipse using master cam and used a font to create some numbers inside of it. When I machine it, all the numbers and elipses are very choppy. I tried using simplify and that did not seem to work. Is there a setting I need to change somewhere?
Here is the g-code. Does it look right? I don't know much about g-code.
N100 G00 G17 G20 G40 G80 G90
N110 G91 G28 Z0.
N120 (WCS NAME - TOP)
N130 (TOOLPATH GROUP - TOOLPATH GROUP-1)
N140 (COMPENSATION TYPE - COMPUTER)
N150 T4 M06 ( 1/2 FLAT ENDMILL)
N160 (MAX - Z2.)
N170 (MIN - Z-.65)
N180 M08
N190 G00 G17 G90 G54 X10.1776 Y.6448 S3100 M03
N200 G43 H4 Z2.
N210 Z.1
N220 G01 Z-.65 F6.42
N230 X9.9715 Y.1892 F25.
N240 G03 X10.221 Y-.4724 I.4556 J-.2061
N250 G02 X11.5802 Y-1.2669 I-2.8967 J-6.5156
N260 X12.6029 Y-2.2304 I-3.6008 J-4.8467
N270 X13.3459 Y-3.4061 I-3.9417 J-3.3135
N280 X13.7405 Y-4.9635 I-4.0873 J-1.8644
N290 X13.4589 Y-6.8215 I-4.3914 J-.2848
N300 X12.7981 Y-8.0217 I-4.6523 J1.7794
N310 X11.8486 Y-9.0209 I-4.6803 J3.4967
N320 X10.556 Y-9.8676 I-4.3825 J5.2809
N330 X10.0261 Y-10.1117 I-3.4454 J6.7828
N340 G01 X7.0906 Y-11.8065
N350 G02 X6.9281 Y-11.85 I-.1625 J.2815
N360 G01 X6.5719
N370 G02 X6.4094 Y-11.8065 I0. J.325
N380 G01 X3.4739 Y-10.1116
N390 G02 X2.0488 Y-9.3272 I2.7623 J6.7053
N400 X.9931 Y-8.3816 I3.5469 J5.0217
N410 X.2322 Y-7.2584 I3.9306 J3.482
N420 X-.2157 Y-5.7946 I4.0718 J2.0464
N430 X.0105 Y-3.7616 I4.3457 J.5455
N440 X.6462 Y-2.5548 I4.6408 J-1.6736
N450 X1.5733 Y-1.5453 I4.6856 J-3.3728
N460 X2.8458 Y-.6833 I4.4171 J-5.15
N470 X4.5482 Y-.0286 I3.6798 J-7.0279
N480 X9.0651 Y-.0589 I2.2012 J-8.5583
N490 X10.221 Y-.4724 I-2.1214 J-7.7514
N500 G03 X10.8814 Y-.2198 I.2039 J.4565
N510 G01 X11.0853 Y.2368
N520 G00 Z2.
N530 M09
N540 M05
N550 G91 G28 Z0.
N560 G28 Y0.
N570 G90
N580 M30
