WCS Discussion
Roger,
Ron took the time to make a step by step screen shot to illustrate this bug and Colin confirmed thru his test as well.
Respectfully, if it's not an issue for you, you need not worry about it.
Again, I don't doubt you have a bug. All bugs should be reported and fixed.
The process I use always works. I've never had an issue, period.
I'm really not trying to argue, and I'm not saying the process of rotating a view is incorrect. I'm just saying if you want to edit an existing view the tools and processes are already there. They always work. it's as simple as using xform dynamic to edit an existing WCS/tplane/cplane.
Without geometry you will get "NEW VIEW #1" as a dealer I would think you would want the simplest method possible to help you showcase the power of Mastercam not telling your customers look you have to do these extra steps to rotate a WCS by creating geometry.
Ron, thank you, thank you!
To me this is an awful lot of controversy over
drawing 2 lines..
As someone who first started using Mastercam in
V5, I remember when there was no WSC and I remember when you had to have a death wish to use
Edit Common parameters.
Of course there is room for improvement, but the current system is pretty darn good concidering where we came from
Dave I still think you are making work than needs to be
Ron, you just provided a detail explaination to prove my point and now you say this?
How so, I don't understand?
PS, I also forgot to mention that if the original view is tied to your stock definition, you also need to go and change that.
I'm going to train people the easier, most consistant, most reliable, easily editable, and most functional way of creating editable views. If this requires a couple of extra clicks, so be it. If your process is to use the "two line" or "gnomon" method, it is simply that, the process. Then the views are easy editable by using xform dynamic to move the geometry that was used to create the view.
Again, rotate view is broken and does not work the way it used to.
Dave, the enhancement request I was referring to was in regard to a "solidworksesque" dialog for creating/manipulating views as was brought up earlier in the thread. This is something I have advocated in the past and would be a big help for people new to manipulating views.
drawing 2 lines..
Of course there is room for improvement, but the currennt
Without this conversation, we would not have known it was a bug. Every user has bugs that are more important or less important to how they use the system so I don't think it's too much converstation.
Roger the customers I deal with do not want extra geometry. If it worked a certain way then they expect to work the same way it did not do tricks to make it work like it use to. The 2 lines is something I have never used since using Mastercam.
Dave what I refer to is just using the "NEW VIEW #1" and dealing with is all. I will deal with it when it comes up until it is fixed. It should update any operations tied to that WCS why you are not seeing it I am not sure.
Eric all good here.
From an organization point of view, I want to maintain the names of my Operations and that's why I can the views OP1, OP2, and so on.
I think you are correct that the operations will get updated with “new view #1”. Mine did not because I did not try to save over the view since I knew it did not work since I had tried that before. As I said, I can use the “new view #1” but I will still need to change the work offset, rename the view and if the stock definition is based on my original view, I will need to update that as well.
Until it’s fixed, I guess I need to live with it.
It may work for you too, Dave, but there is no way to know without trying it!
Leigh,
I have no doubt at all that this method works but I am NOT going to use it. wink.gif
Part of the reason is that I only have the issue I decribe if I need to rotate an existing WCS and I don't need to do this all the time so I am not going to start using a work-around for something that's not always needed.
I think the real misconception here is that the "two line" method is a workaround, which is simply not true.
Having a view associative to geometry allows you to edit that view, there is no other reason to have a view associative to geometry. This is the way I have done it since V9 came out with the WCS view manager.
It is a powerful tool also.
We do large weldments here that are pretty much proven files.
Rather than spend hours or days trying to get the weldment perfectly aligned on the machine tool,
we'll slap it up there and take a couple of trial cuts.
Then we figure out the neccessary shift amounts
and move/rotate/translate the 2 WSC definition lines, post and go..
