How to convince a stubborn 9.1 guy to go to X2?
Daniel M
  • Replies 51
  • Created
  • Last Reply
Top Posters In This Topic
The real solution is to have MCX optimized for startup time.
You're in luck.
Start, Programs, MastercamX, MCAMX Control Panel Applet. Selwct Mastercam X3 (or whatever the latest release you have installed), and check the "Show Splash Screen at Startup". This sill significantly slash startup time.
Also, generally speaking, applications launch MUCH faster the second time you launch them. So in the morning you would fire up Mastercam X. It will take however long it takes. You do your thing, close Mastercam. Come back sometime later, fire it up again, it should only take a fraction of the time it took the first time. But since you like to count seconds, lets take a look at what substandard workstations cost the average user... 2 seconds per launch at 200 launches is about 27.77 HOURS per year (based on 5 day work week at 50 weeks per year). Standard shop rate let's say is $60 so you're spent $1,666.66 in wasted time. $4,000 workstations are out there but most people do not need them and there are some very nice workstations right around $1,000-$1,200. So, without going out and buying a new computer, you've already paid for it in wasted time.
JM2C
I have tried to learn X2 but have not been able to learn it. Belive me, I have tried.
Maybe it has something to do with my learning ablities(not trying to be funny).
But up to version 9.2 eveything was pretty simple.
X2,X3 I cannot get the hang of it.
Machine definitions,tool paths,tools menu,all confuse me.
I do want to learn it and will keep trying.
So true James. In Vista, Catia launches in 15 seconds flat. In XP or previous OS's 90 seconds is the norm. Vista learns your use habits rather than let RAM sit unused, it will pre-load programs so they launch in about the time XP did for the second launch.
Don Trust we just put new Dell optiplex Dual core 3g with 4 gigs a ram and vista buss with a Quardro 1700. for about $1500 a pop and mastercam X3 mu1 launchs as fast as the old V9. it luanchs faster them my work box that is a
Daul Quad core xeon 3.4's
Win X64
8 gigs ram
Quadro 5600 1.5g ram
that cost $10,000 buy the IT guys.
Everything has a cost. EVERYTHING! Doing nothing has a cost. Inefficiency has a cost. It takes a while to train yourself to see the real costs of things but once you do, you'll look at things A LOT differently in life. It helps to be able to distinguish needs from wants.
Between the interface improvements in X AND the purchase of my SpaceNavigator... the time savings has been tremendous compared to the cost.
Whew!
OK, I guess I exagerated on the 200 times a day. Sheesh.
Jay, thanks for the ifo on the Dell. Right now we have a Dell precision 380 with 4 gigs, and an FX1400 quadro card. Maybe time to upgrade.
JM2C, I'll try the getting rid of the splash screen. Thanks for the tip.
Hardmill, thanks for the links. Again, maybe it's time to upgrade a bit.
I thought splash screens were just something pretty to look at while your software was starting up...making no difference in actual start time. It *seemed* like it was quicker to view the splash screen because it kinda "passed the time" while staring at a blank screen would *seem* to take forever.
Thad
Daniel,
Something to consider.
Get a part that neither of you have seen before. Something that would take maybe 1/2 hour to an hour to complete. Have you both start at the same time. Hopefully, you finish first with X3. :-)
anyway, assuming that happens, maybe you could then show this guy WHY you finished first because of the better tools available with MCX?
Just a thought. I know it's kind of a backdoor way to get thru to him/her, but it might prove useful.
Perhaps even better would be a part that could ONLY be completed with MCX, assuming there is a beast.
I still use Mill 9.1 SP2 5 axis here. I missed a couple opportunities to get in for a good price from my reseller. I know that X would probably be a better world to be in. I almost never have the same job twice and I have not found one thing that was required that I could not program with what I have.
Some of the projects are very simple and others are quite complex.
Today I am cutting out some beams and corbels for T Boone Pickens to go in a conference room up in the pan handle in Texas. Last week I made custom volutes and handrails for several stair company's. Next week I will be making custom moldings for some of our jobs in Dallas.
If I had X I might be able to go a little faster or I might like some tool paths that I don't know anything about, but for now I can get a long just fine. smile.gif
The advanced 5X toolpaths introduced in X2 are
very powerful.. the learning curve is a little steep, but they'll run circles around basic 5X.
There are also 2 pricelss Chooks from Verisurf
Hole Axis is one.. and another very powerful one coming out in X4.
If you do a lot of 5X stuff.. you owe it to yourself to look into Advanced 5X.
For example.. to finish the floor bewteen 2 blades of an impeller, we used to draw a C/L chain
and use 5X curve..it would take hours to draw the chains just right..and we'd need a seperate chain for roughing and finishing.
Now I use the left and right wall surface, the floor surface and the "morf between 2 surfaces" toolpath... To change between roughing and finishing.. copy the toolpath and change the step
over value.
I think it depends on what you are doing. Some people need to only create a quick 2d sketch and export to dxf/dwg.
In this case, why on earth would you pay more to upgrade to something that has a long list of new features you don't need and spend months learning something that in the end, was completely unnecessary?
All I'm saying is some guy in a small job shop may have zero need to upgrade to X, let alone Windows XP.
