X3 Mill suggestions and improvements
Redfire427
gcode, you must be darn lucky. I experience it
every time I open my Outlook and a few others.
Two Windows of MC, fogetaboutit.
Firefox open does not effect it thank God.
Until I reboot my system after opening outlook
will it be back to normal.
Closing MC does not always fix it.
that is software related
200 to 300 mg files and then ya also have to worry
about severe crashing. Never in all my years of
programming have I seen files created by cam soft
ware get so huge. I use only half the tolerence
I use to use in smurfcam and the files are still
10x larger
Right now I have 2 copies of MC open (about 30 meg filesize)
1 copy of SW 2008
1 copy of AutoDesk Deign Review
1 copy of Cimco Edit 5.0
1 IE7.0 Window
and Outlook 2003
The system is rock solid.. I honestly can't remember
the last time I had a crash.
One thing I won't allow on my systems
is the new Windows/Outlook Search utility
that will slow any computer to a crawl.
While I won't disagree with this, the biggest question is why does MCAM keep having lag, errors and crashes
No of the other installed software is doing this.
Hey; we could have the kind of troubles that powermill users have, here's a quote from their forum:
I am running a dual 64 bit Opteron with 64 bit XP Pro.
Nvidia Quadro FX graphics card
SATA RAID drives
10 gig of ram
I am getting the "PowerMILL has almost run out of memory. It may crash or become unstable. Break has been set."
I am working on a large project with alot of pattern machining. I am only doing 3 pattern cuts at a time. I then empty the patterns, delete the tools paths and the NC programs and also empty the trash can after every set of 3 cuts. I do about 4 or 5 sets of cuts like this and PowerMILL craps out. It did this when I only had 4 gig of ram. So we thought we needed to add more ram, so we did. Windows reports that I now have over 10 gig of physical ram. Adding more RAM didn't help a DAMB thing Evil or Very Mad
What gives here? Confused
Wish I had powermill to prove that.
(Never compare or reference your software to something you
denounce. I never paid for 'powermill' so reassure
me that the issues even JP complains about in MC
will get better, THATS what i bought maintenance
for, and another seat.)
gcode
I rarely have under 100 meg files, in MC
i just finished a core block that is 276 mg
The cavity 168 mb and I dare not use under .0006
tolerance.
I don,t seem to have lag problems if I close MC,
All in all if I just work on one at a time and no
email, I am good. I haven't had a crash since
The SP1 came out just lag on the above issue.
I also notice that if I move or copy geometry
to a level and search for the lvl rather than
type in the lvl, i wait 7 or 8 sec for the lvl
window to pop up.
If i know the lvl and punch it in then it is
instantaneous.
The one thing that really bugs me is the dirty
path thing. Why does the path disappear?
I still can't get over that. It should just mark
the path so that you know something is changed.
but disapear??? Why..why...why......why
This gives engineering changes a whole new PITA.
I know of 3 softwares that paths don't disappear.
In a John Lennon voice:
I'm not saying that Mastercam is better or more popular than other software, I'm just saying smile.gif
As for your files growing huge, parametric surfaces will do this when translated around they leave copies of the trims blanked in the original position. This tends to make the files grow huge quick. Where does your geometry originate?
Allen,
I have several UG native files that average 20 to 35 megs. One of the larger one when opening in MCAM is 400 megs upon complete opening in MCAM, which takes several minutes BTW
I just thought of one thing all these trouble free machines have in common.
None of them have ever had X or X2 installed on them.
The new Dells had V9 and X2_MR1 installed on
them when they were new.
The older machines all got a disk format/OS reinstall when X2_MR1 came out.
In summation.. there are no old X or X2 dll files lurking in these systems.
Sorry Allen,
you made it sounds like, 'at least its not
as cumbersome as powermill, yet.'
Some files i get are igs, stp, parasolids etc.
created in solid works, Ug, Pro e, etc.
The files only get large from tool pathing, in
most of my cases.
I split the files into separate mold components and
place them in cut position, like I have done in
every software that I have ever used.
I never make copies unless i get new data for
changes.
for example
What choice do I have but to move the old geo
to a different level, and bring in the new geo
place it, just so my paths don't go dirty, just so
I can see what they did with what geo they made
with.
aggravating and time consuming, so now I do
all EC's in a different environment prior to
bringing it into MC. This is actually faster.
MC's tool paths are my reason for using MC
Left over and rest and re machining are top notch.
if I have Geometry that comes in over 50 meg
I will read it in solid works and translate it
out then into mc, it can reduce it by half the
size
with.
Rick, have you tried the change recognition in the file menu? It should save you some steps.
Gcode,
thanks for the suggestion on the stl file. I'll give it a try.
I have, finally, gotten rid of the crashes (complete uninstall, got rid of all old versions of mc except X2SP1, clean reg, install MR2 as a stand alone), but the lag and large files are annoying. Now when I go to post my toolpaths all my toolpaths in my ops manager "disappear" while mc thinks about posting it, before the final ok to transfer the file to my machines. cuckoo.gif Just glad I'm not the only one having these kinds of issues.
I think I've had a couple crashes but most of them seem to stem from my SpaceNavigator... meaninf I'll try to rotate something and it will just hang, then bring up the box you can send the issue to Mastercam... and I do. It's not annoying. I use Autosave and it saves every 10-15 minutes...
Time based retract for tool inspection on 2D toolpaths ...... I know its in the High Speed Option, but it would be nice when machining some bad assed materials to have the tool retract up for inspection.
You just press a button on the Hurco machine ......
No problems running X2 MR2 SP1 ..... hasnt crashed yet, seems stable with Outlook, CIMCO, Inventor 2008. . . . .
Before you go mad dog on your computer
try uninsatlling ALL Mastercam products
the clean your registry with this
Then reinstall V9 (if you still want it)
and then X2_MR2.
You can really jack a computer up if
you install older versions of Mastercam
on a machine after newer versions are installed.
ie (installing X2 then X can cause big trouble)
Mad dog, with rabies, evan...lol
gcode
I started with X2 in Oct 06, a week prior to the
release of X2, 3-P.C's ago
I am not installing anything but X2 MR2 SP1
if I format or reg. clean
This lag thing sucks, I got this PC in Aug and
installed X2 SP1, got maintenace in Nov and
Installed X2 MR2,then SP1
Its like I am on a old hyper threading chip??
Have you ever used abexo reg cleaner?
That is the only one I have used/trust
guess it wouldn't hurt to try ccleaner
Rick
abexo reg cleaner
No , I've never tried it.
I've been using CC Cleaner for a couple of months
and the price is right.
I'd try an uninstall and reg clean before going the lobotomy route.
As a beta site , I do it pretty often and it usually fixes weird behavior.
I'd haven't seen the lag issue in a long time, but
your files are way larger than mine so that may
have something to do with it
I too agree with those above that a "bug fix only" MR needs to be released. NO NEW FEATURES (even though different S & F on contour finish cut would be quite nice), just bug fixes. Many of us have submitted bug reports. Some major ones have been addressd, but many simple ones still exist from way back. I think CNC Software would do well in listening to existing users rather that marketing for at least one maintenance release. After all, ISN'T THAT WHAT WE PAY FOR?
