Need help!!!
Thirteenth
  • Replies 101
  • Created
  • Last Reply
Top Posters In This Topic
my question, does it matter where the part is drawn in mastercam in relation to 0,0,0.
Yes,and No... You can manipulte your 0,0,0 with WCS. Your machine still has to know where your part is. If you draw your part 20" away and the machine has 15" travel than you will get an axis overtravel.
(PROGRAM NAME - O8765)
(DATE=DD-MM-YY - 18-12-03 TIME=HH:MM - 19:59)
N100G20
N102G0G17G40G49G80G90
(3/16 FLAT ENDMILL TOOL - 1 DIA. OFF. - 41 LEN. - 1 DIA. - .1875)
N104T1M6
N106G0G90G54X6.2228Y8.0831A0.S2852M3
N108G43H1Z.25
N110Z.1
N112G1Z0.F6.16
N114Y8.6047Z-.0273
N116X6.1018Y8.8906Z-.0436
N118G3X5.579Y9.1006Z-.0739R.7557
N120X5.0563Y8.8906Z-.1041R.7557
N122G1X4.9353Y8.6047Z-.1204
N124Y8.0831Z-.1477
N126X5.1091Y7.889Z-.1614
N128G3X5.579Y7.7431Z-.1876R.8295
N130X6.049Y7.889Z-.2137R.8295
N132G1X6.2228Y8.0831Z-.2274
N134Y8.6047Z-.2547
N136X6.1018Y8.8906Z-.271
N138G3X5.579Y9.1006Z-.3013R.7557
N140X5.0563Y8.8906Z-.3315R.7557
N142G1X4.9353Y8.6047Z-.3478
N144Y8.0831Z-.3751
N146X5.1091Y7.889Z-.3888
N148G3X5.579Y7.7431Z-.4149R.8295
N150X6.049Y7.889Z-.4411R.8295
N152G1X6.2228Y8.0831Z-.4548
N154Y8.6047Z-.4821
N156X6.1018Y8.8906Z-.4984
N158G3X5.579Y9.1006Z-.5286R.7557
N160X5.0563Y8.8906Z-.5589R.7557
N162G1X4.9353Y8.6047Z-.5752
N164Y8.0831Z-.6025
N166X5.1091Y7.889Z-.6162
N168G3X5.579Y7.7431Z-.6423R.8295
N170X5.7245Y7.7559Z-.65R.8295
N172X6.049Y7.889R.8295
N174G1X6.2228Y8.0831
N176Y8.6047
N178X6.1018Y8.8906
N180G3X5.579Y9.1006R.7557
N182X5.0563Y8.8906R.7557
N184G1X4.9353Y8.6047
N186Y8.0831
N188X5.1091Y7.889
N190G3X5.579Y7.7431R.8295
N192X5.7245Y7.7559R.8295
N194G0Z.25
N196X6.1728Y8.1022
N198Z.1
N200G1Z0.
N202Y8.5946Z-.0258
N204X6.0598Y8.8614Z-.041
N206G3X5.579Y9.0506Z-.0687R.7057
N208X5.0983Y8.8614Z-.0964R.7057
N210G1X4.9853Y8.5946Z-.1116
N212Y8.1022Z-.1374
N214X5.1423Y7.9269Z-.1498
N216G3X5.579Y7.7931Z-.1741R.7795
N218X6.0158Y7.9269Z-.1984R.7795
N220G1X6.1728Y8.1022Z-.2107
N222Y8.5946Z-.2365
N224X6.0598Y8.8614Z-.2517
N226G3X5.579Y9.0506Z-.2794R.7057
N228X5.0983Y8.8614Z-.3071R.7057
N230G1X4.9853Y8.5946Z-.3223
N232Y8.1022Z-.3481
N234X5.1423Y7.9269Z-.3604
N236G3X5.579Y7.7931Z-.3847R.7795
N238X6.0158Y7.9269Z-.409R.7795
N240G1X6.1728Y8.1022Z-.4214
N242Y8.5946Z-.4472
N244X6.0598Y8.8614Z-.4624
N246G3X5.579Y9.0506Z-.4901R.7057
N248X5.0983Y8.8614Z-.5178R.7057
N250G1X4.9853Y8.5946Z-.533
N252Y8.1022Z-.5588
N254X5.1423Y7.9269Z-.5711
N256G3X5.579Y7.7931Z-.5954R.7795
N258X6.0158Y7.9269Z-.6197R.7795
N260G1X6.1728Y8.1022Z-.632
N262Y8.4448Z-.65
N264Y8.5946
N266X6.0598Y8.8614
N268G3X5.579Y9.0506R.7057
N270X5.0983Y8.8614R.7057
N272G1X4.9853Y8.5946
N274Y8.1022
N276X5.1423Y7.9269
N278G3X5.579Y7.7931R.7795
N280X6.0158Y7.9269R.7795
N282G1X6.1728Y8.1022
N284Y8.4448
N286G0Z.25
N288M5
N290G91G28Z0.
N292G28X0.Y0.A0.
N294M30
that is the code that works, well loads.
OK, now I'm confused. I did a side-by-side comparison of your 'non-working' file and your new 'working' file and the code is identical except for the program number and one tenth on an arc move:
G3 X5.579 Y7.7931 R.7795
vs.
G3 X5.5791 Y7.7931 R.7795
Did you change filtering or something to create this difference?
Strange...
C
I always orient my drawing in regards to 0,0,0.
It is easier for me to do it that way so when I set my machines up you dont have to do alot of figuring or inserting machine offsets in the control.
I did have a small problem where sometimes my control would fault out if 0,0,0 was in the same place as the center of an arc in the cutterpath.
So whenever I got this fault, I just set the origin .0001 off in the x and y.
Murlin
I wonder if the Machine even uses a G54
I agree. Since all of his X and Y numbers are positive AND relatively large for what I assume is a small machine AND the first working program had no work offset call.
As far as Work Offset zeros I like to work off the back left in a vise and the center of round parts whenever I can though I'll set it up differently sometimes if the dims on the print all come off of some other location so the operator sees numbers on the screen that make some sense when compared to the drawing.
C
Another little thing I like to uue for Parts is the Bounding box. I will usually create this on a seperate layer so I can turn it off and on when I need it. I use this for facing and other things like using the point in the center for a WCS or to translate a part to the origin.
Just in case you wonder where it is. Create/Next Menu/Bounding Box.
Crazy Millman
Thad,
I see the college teaches real world machining practices. Disable door interlock, run with chip guard open and place a hand as close to the cutter as possible (to reduce chatter). I can't tell, but, I would guess the operator has his saftey glasses properly placed on the top of his head and not on the bridge of his nose. J/K biggrin.gif
Phil
Thirteenth,
From the looks of the code you supplied us earlier and the photo that Thad supplied I would say the easiest thing for you to do is Xform-Translate your geometry from the location it is on your screen, to Mastercam's Origin. You can then regenerate the toolpaths and re-post it and you should see the coordinate values in the appropriate range of motion (work envelope) for that machine. Let us know how you do.
Don't let these guys fool you. Kidding aside, those who contribute here are among the best in the business. Welcome aboard. HTH biggrin.gif
I dont understand why Everyone doesn't already do it this way in the first place.....Cause it seems like the logical way.
+1000
Murlin
[ 12-24-2003, 02:26 PM: Message edited by: Murlin ]
Luckily, I never had to run that machine. I went to a school that had a Haas machining center and turning center.
These are the CNC machines that thy have here where I just finished up my MC class. Here is their lathe.
LinkPhoto?GUID=5471248c-7e0e-1616-4537-17d22b611c93&size=
Our computer lab was inside the machine shop. I took my camera in one night to get some pics. I had a classmate put his hand in the picture to give you an idea of how big these machines were.
Thad
  • 3 weeks later...
