Need help!!!
Thirteenth
Ok, I have just started using, well started this year, mastercam. Our school has the older V8 and V8.1.1 of this.
I have been in CAD class for 4 semesters now, I know how to draw in autocad decently and rhino pretty well to. Could learn a few things i magin.
anyway, im having problems. here is what i have done.
I drew up a part that i planned on making. I drew this in autocad2000. I then opened it up in mastercam, not as a dwg, but as some other type of file. i dont remember what kind. if this matters, i can find out.
Ok, so its in MasterCam, looking good and all. I start making the toolpaths. I used contour and then chain. basicly i got all the toolpaths made, only 2 actually. I can verify it just fine, it looks good.
Ok, teacher says ive done all i need. So we start to do the next step and make it on the machine.
Its a EMCO PC 50 mill. we used the EMCO program that i guess came with the mill. Well we open it up and everything, load the stuff, but the "program" wont load. It says the "MC30" isnt there.
I dont know where i went wrong. If you need more details, please let me know what you need to know! Or if you know how to fix this, please, please, post! thanks a ton.
-Jay
  • Replies 101
  • Created
  • Last Reply
Top Posters In This Topic
Well I would that that is like a Regular M30 and you may just need to change the Definiton in the Post to make it be a MC30 verse what is might be now. Put up some sample code and someone can tell you real quick what you have by looking at the starting and ending code.
Oh yeah welcome4.gifFORUM
Crazy Millman
[ 12-16-2003, 10:34 PM: Message edited by: Millman^Crazy ]
If Millman is correct, and the end of file should read MC30, you can open the post and look for this..
peof            #End of file for non-zero tool
iseof = 1
pretract
iseof = 0
spaces=0
comment
spaces=sav_spc
#Remove pound character to output first tool with staged tools
#if stagetool = one, pbld, n, *first_tool, e
#pbld, n, "G52", "Y0.", e
if stagetool <> 0, pbld, n, "M06", e
if t <> first_tool, n, first_tool, "M06", e
if sav_mi3 = 1, n, "M33", e
n, "M30", e
The last line,
n, "M30", e
needs to be changed to
n, "MC30", e
Save and re-post.
(BTW, you can edit the machine code first to see if that's it, just open it in notepad or whatever and go to the end of the file and look for the
and change it to
MC30
and try to send it again.)
'Rekd
Welcome to the forum
I echo what the other cats said about putting up some code like you want it to look and some the way you're getting it now; we can advise you on what you need to do from there.
As far as editors go I'd use the CimcoEdit that you have with your Mastercam seat to edit as it has many NC functions that pure text editors do not.
C
The thing about most notepads or other editors of that sort is that they always want to save a files as a TXT extension. If you look at a post it is a PSB extension and if you edit them in the noepad or soemthign that doesn't give you the freedom like the old dos editors use to them it can be a freaking night mare. The Cimco or any other editor that ships with Mastercam(To use these go to File/Edit/Editors here it will allow you to select which one here) I am not sure if a student version uses a hasp if it does not it will not allow this. One of the other Teacher Members should be able to fill in that blank.
Crazy Millman
O0000
(PROGRAM NAME - O1578)
(DATE=DD-MM-YY - 17-12-03 TIME=HH:MM - 07:22)
N100G20
N102G0G17G40G49G80G90
(3/16 FLAT ENDMILL TOOL - 1 DIA. OFF. - 41 LEN. - 1 DIA. - .1875)
N104T1M6
N106G0G90G54X6.2228Y8.0831A0.S2852M3
N108G43H1Z.25
N110Z.1
N112G1Z0.F6.16
N114Y8.6047Z-.0273
N116X6.1018Y8.8906Z-.0436
thats the very begining of the code.
N244X6.0598Y8.8614Z-.4624
N246G3X5.5791Y9.0506Z-.4901R.7057
N248X5.0983Y8.8614Z-.5178R.7057
N250G1X4.9853Y8.5946Z-.533
N252Y8.1022Z-.5588
N254X5.1423Y7.9269Z-.5711
N256G3X5.5791Y7.7931Z-.5954R.7795
N258X6.0158Y7.9269Z-.6197R.7795
N260G1X6.1728Y8.1022Z-.632
N262Y8.4448Z-.65
N264Y8.5946
N266X6.0598Y8.8614
N268G3X5.5791Y9.0506R.7057
N270X5.0983Y8.8614R.7057
N272G1X4.9853Y8.5946
N274Y8.1022
N276X5.1423Y7.9269
N278G3X5.5791Y7.7931R.7795
N280X6.0158Y7.9269R.7795
N282G1X6.1728Y8.1022
N284Y8.4448
N286G0Z.25
N288M5
N290G91G28Z0.
N292G28X0.Y0.A0.
N294M30
thats the end part of the code i just got. if ya need something else let me know.
[ 12-17-2003, 10:50 AM: Message edited by: Thirteenth ]
Please post a verbatim sample of post processed code including the exact file name including .XXX.
Also please post a verbatim sample of code that has run in the machine, particularly the start and end lines including exact file name.
Sometimes little details like % or ; in the wrong place mess things up.
As posted, File name: 213153.TXT
(213153)
(PROGRAM NAME - 213153 DATE=DD-MM-YY - 15-12-03 TIME=HH:MM - 13:52)
(POST LICENSE - VEECO)
(TOOL - 21 OFFSET - 21)
(DRILL #1 CENTER DRILL .046)
G20
N100 G28 U0.
G28 W0.
M200
T2121.0008 B24
deleted code
X8.6041 Z-.1538 C84.197 Q188
X9.0753 Z-.1538 C96.326 Q188
Z-.1538 C83.674 Q188
G80
M9
G69.5
Y0.
G28 U0.
G28 W0. M205
Proven code File name 213153.EIA
(213153)
G20
N100 G28 U0.
G28 W0.
M200
T2121.0008 B24
deleted code
G80
M9
G69.5
Y0.
G28 U0.
G28 W0. M205
Notice the % is missing from the proven code??? And the file name is different? These are the details required to get you zooming.
Edit: Maybe I should clarify that your code does not need to look exactly like my code. It needs to look exactly like like code that has been proven in your machine and we will help you look for the details.
[ 12-17-2003, 12:19 PM: Message edited by: Harryman ]
O0000
(DATE=DD-MM-YY - 17-12-03 TIME=HH:MM - 09:15)
N100G20
N104T1M6
N108G43H1Z.25
N110Z.1
N112G1Z0.F6.16
N114Y8.6047Z-.0273
N118G3X5.5791Y9.1006Z-.0739R.7557
N120X5.0563Y8.8906Z-.1041R.7557
N122G1X4.9353Y8.6047Z-.1204
N124Y8.0831Z-.1477
N126X5.1091Y7.889Z-.1614
N128G3X5.5791Y7.7431Z-.1876R.8295
N130X6.049Y7.889Z-.2137R.8295
N132G1X6.2228Y8.0831Z-.2274
N134Y8.6047Z-.2547
N136X6.1018Y8.8906Z-.271
N138G3X5.5791Y9.1006Z-.3013R.7557
N140X5.0563Y8.8906Z-.3315R.7557
N142G1X4.9353Y8.6047Z-.3478
N144Y8.0831Z-.3751
N146X5.1091Y7.889Z-.3888
N148G3X5.5791Y7.7431Z-.4149R.8295
N150X6.049Y7.889Z-.4411R.8295
N152G1X6.2228Y8.0831Z-.4548
N154Y8.6047Z-.4821
N156X6.1018Y8.8906Z-.4984
N158G3X5.5791Y9.1006Z-.5286R.7557
N160X5.0563Y8.8906Z-.5589R.7557
N162G1X4.9353Y8.6047Z-.5752
N164Y8.0831Z-.6025
N166X5.1091Y7.889Z-.6162
N168G3X5.5791Y7.7431Z-.6423R.8295
N170X5.7245Y7.7559Z-.65R.8295
N172X6.049Y7.889R.8295
N174G1X6.2228Y8.0831
N176Y8.6047
N178X6.1018Y8.8906
N180G3X5.5791Y9.1006R.7557
N182X5.0563Y8.8906R.7557
N184G1X4.9353Y8.6047
N186Y8.0831
N188X5.1091Y7.889
N190G3X5.5791Y7.7431R.8295
N192X5.7245Y7.7559R.8295
N194G0Z.25
N196X6.1728Y8.1022
N198Z.1
N200G1Z0.
N202Y8.5946Z-.0258
N204X6.0598Y8.8614Z-.041
N206G3X5.5791Y9.0506Z-.0687R.7057
N208X5.0983Y8.8614Z-.0964R.7057
N210G1X4.9853Y8.5946Z-.1116
N212Y8.1022Z-.1374
N214X5.1423Y7.9269Z-.1498
N216G3X5.5791Y7.7931Z-.1741R.7795
N218X6.0158Y7.9269Z-.1984R.7795
N220G1X6.1728Y8.1022Z-.2107
N222Y8.5946Z-.2365
N224X6.0598Y8.8614Z-.2517
N226G3X5.5791Y9.0506Z-.2794R.7057
N228X5.0983Y8.8614Z-.3071R.7057
N230G1X4.9853Y8.5946Z-.3223
N232Y8.1022Z-.3481
N234X5.1423Y7.9269Z-.3604
N236G3X5.5791Y7.7931Z-.3847R.7795
N238X6.0158Y7.9269Z-.409R.7795
N240G1X6.1728Y8.1022Z-.4214
N242Y8.5946Z-.4472
N252Y8.1022Z-.5588
N262Y8.4448Z-.65
N264Y8.5946
N266X6.0598Y8.8614
N274Y8.1022
N276X5.1423Y7.9269
N284Y8.4448
N286G0Z.25
N288M5
N290G91G28Z0.
N292G28X0.Y0.A0.
N294M30
that is the entire NC file. now...this is only 1 chain for the part that i need to do. I want to get something made, so i know im going in the right track.
now, what is going wrong here? why isnt it reading?
is the
O0000 wrong? should that be changed to O1578
should the % at the very begining be deleted?
I don't like the O0000; try it with O [that's 'Oh', not zero] and a number: O1234
% usually wants to be there
can you get any other files to transfer to the machine and work? what do they look like? don't really get the 'N5' thing because there isn't one in your program
please post a file here that ACTUALLY WORKS so we can see it
C
i would post one, if there was one on this computer. the computer that has one that works, does not have the internet. so yeah, little stuck there.
but it doesnt look anything like this one. Teach said its cuz they are completly different things, mine is a 3d type object, his was just a flat thing w/ MC wrote on it.
Can you save the working code to a floppy, and then get it to the online computer?
It doesn't matter whether the parts resemble each other. We need to see the details of the code that works. Write it down and type three lines or so from the beginning and end of the working program if that's all you can do.
If this machine was communicating, it would seem to me that the problem lies with the code itself, and I see several places where this could be an issue. First thing I would do is strip all the comment stuff. Next I would strip all of the fourth axis stuff. And finally I would look at some of helical moves. It's my guess the control doesn't like lines like
"N118G3X5.5791Y9.1006Z-.0739R.7557"
