Programmer to machine ratio.. I'm curious
Mick
I'm curious about the programmer to machine ratio out there in various companies.
I'll start off. We have 25 NC machines, comprising of 8 two axis lathes, 5 Multi Axis lathes (MT's/Multus), 1 twin chuck C-axis lathe (Mori Seiki DL), 3 Vertical machining centres, 7 horizontal machining centres, one vertical lathe (with pallet (chuck) changer, and C axis).
We have five programmers, three skilled in multi axis, and the other two up to four axis.
Obviously our workload is up and down, but I am curious to see the ratio other companies have for programming to machine tool numbers.
60+ machines including 3 5 axis mills and bunch of big HBM's with double rotary setups, HMC's , VTL's and VTL mill turns
We have 3 programmers working 12 hour sifts.
2 mutiaxis mill/lathe guys and one lathe only guy
We are not a job shop and a lot of our work is repeat business. In a job shop environment
3 programmers would get buried alive trying to support that many machines.
1 programmer
1 72" between center 30" swing Fanuc Lathe.
6 2 axis Okuma Lathes.
1 4 Axis Okuma Lathe with live tooling no Y axis.
1 7 axis Mazak Lathe 22" between chucks with live tooling and Y axis.
1 9 axis Integrex Lathe 52" between chucks Cat 40 taper
3 4 axis Mills 2 Fanuc one Okuma Cat 50 taper
1 96" x 40" 3 axis mill (Dino Clump is what I call it) bt50 taper
Verisurf Programming of 5 axis CMM
Seat of Job Boss for Planning
MBD administration
Quoting of some work
We area job shop yes I am buried I just looked at my 45 point bulletin of action items I have probably 400 hours work of work all needing to be done right now. Guess what it gets done as it gets done.
One programmer here (me) 2 shifts JOB SHOP
Lathes
Haas
3 SL30 with C axis
1 SL20 C axis
1 TL2 TOOLROOM
1 Daewoo 250L
Mills
Haas
2 VF8s 5 axis
2 VF3s 5 axis
3 VF2s
3 TOOLROOM MILLS 4 AXIS
3 FADALS
1 Haas EC200O HORIZ. 5 AXIS
6 PROTRAK MILLS
Wire
CHARMILE ROBO 310
CNC OKUMA GRINDER
VERISURF AND FARO ARM
20 machines:
-profilers
-5 and 6 axis milling machines (with
interchangeable heads).
-lathes
-9 programmers. All programmers have a side line as Vericut support, ICAM or probing. Machines are pretty complex and we're on Catia. Lots of PPInstructions, and also Vericut takes quite long to run big parts. They keep all 9 of us pretty busy.
30+ machines about half of them 5-axis.
5 of them are Mag3's and those alone can keep 2 programmers busy.
Typically lower production mid to large sized aircraft parts.
5 Programmers. 1 in training.
2 on CATIA the rest on Mastercam.
6 VMC's
2 2 axis turning centers
1 sub, live tool lathe
2 programmer, set up operators for the mills +1 in training
1 for the lathes
A few part timers for machine tending and part loading as needed.
Job shop, 1-50 part lot size tight tolerance(+/-.0005 or less) complex parts. Some parts run for as long as 12 hours.
LMAO!!
You get a machine, a print and material.
Get it done from day one or theyll know what your capable of.
Thats the reason everyone comes in as a contractor so they can weed out the ones that dont cut it.
Maybe I should clarify the programmer part.
