The New 2017 Interface
112 members have voted
  1. 1. Does the new interface help your work flow?
    • Yes
      17
    • No
      70
    • Unchanged
      7
    • Undecided
      18
I believe you can only have one workspace file and it must be named
mastercam.workspace
Well if that's the case, then that's not good.
I find it much easier to load my work space when I'm helping out on someone else's computer, rather than trying to navigate through their customized interface.
Yet more frustration...
man this is so easy...put an x in front of his workspace file and then copy yours into the config directory...
If there is no workspace file, Mastercam makes a new default one.
You could have a million different workspace coinfigs in there just rename the one you want to use to default name.
Thanks for your reply. Still not as easy as X9 :thumbdown:
This was/is my biggest complaint about the new interface. Depending on if I am driving a lathe or a mill or a mill/turn or even a wire my RMB menu was tied to a workspace. Programming for a lathe....change the workspace, and all of my customization's (mainly toolpaths) are in my RMB menu. New job, mill time? change workspace and now I have all of my most common mill toolpaths right there. I brought this up in the official forum to basically deaf ears.
Yes, they remove opitcore, my most used tool path......
unless they renamed it
so far my testing in 2017 has been all 2-d
It was re-named. Both opti-core and opti-area are now consolidated into just one toolpath called OptiRough. To switch from Core/area now its just an easy check box, Check inside for area type results and check the outside check box for Core type results.
They have also done the same thing to the 2D dynamic area and 2d Dynamic core, they are now just "Dynamic" with a checkbox for Inside / outside to switch from area to core/
so without any significant updates to toolpaths, apparently, and toolpaths being the true end result of our work, i'm having a hard time being compelled to install 2017 and may skip it entirely. any idea what toolpath improvements might be released in the next version?
are there any significant updates to toolpaths from X9 to 2017?
stock model is more robust.
minor upgrades to circle mill
2d dynamic has new more direct return passes
and a new highlight feature that shows you what is going to get cut before you exit the chain manager
Lathe roughing is much better
I used to struggle avoiding light passes and such
they work very well now without too much effort
the big change is the 5X tool path  interface
It's been totally overhauled and is a big improvement on X9
the planes manager is new as well and I really like the View button
It has been a big help in figuring out how lathe actually works with VTL's
I'm sure there's more but it slips my mind at the moment
and a biggy I forgot
you can import vendor supplied step files to create tools and tool holders
this woks so so with tools ..mostly due to the quality of the vendor models
but it works perfectly for tool holders ..
I use a lot of Sandvik Capto tool holders and they come it exactly right
You can't do it through the standalone tool manager though can you? It is only through the Add Holder function in the toolpath itself?
this is true
the reason being... the tool manager is a stand alone app outside of Mastercam
and a second step license would be required for it to function properly...
but once you've created them, you can move to the tool manager and use them like any other holder or tool
this is true
Interesting :).
I was curious as to how Vericut handled it. Vericut doesn't use the STEP license, until the Tool Manager is opened. I'm guessing that (technically), you don't use the STEP license in Mastercam unless you are actually translating a STEP file, which means that in reality, the license *could* be available to the standalone toolmanager if necessary.
I'm guessing the function just isn't in the standalone tool manager at the moment.
As you point out though, the holder can be imported within the toolpath, and then then opened in the Tool Manager :)
Have you used any of the twin tools? I just asked our reseller yesterday and he said they are not supported, but you can fudge the offset numbers to make them work. Also, what is the advantage of using an actual solid for a tool holder and/or tool? I always kind of thought having the premade libraries and not needing a solid was an advantage?? Have a guy using another software and he has to import solids for toolholders, which I think sucks, but maybe I am missing something...
MC2017 doesn't use actual solids for the tool holders
it does a solid slice, then revolves the geometry to define the holder.. the same way you'd build
a custom tool or customer holder.
The only difference is MC2017 is doing the work for you
If the supplied standard holder libraries are adequate, you won't use this feature much.
I use a lot of Capto holders,
Capto is a modular system where you assemble various components to build a holder
In the past I had to build the components in the holder builder manually, which could take some time.
Now I use the Sandvik supplied step files and get an accurate holder in seconds
This is a Capto stack I used with X9. It's made of 4 componemts
and I had to build the holder manually in the holder builder
http://www.emastercam.com/board/topic/82486-capto-rules/?hl=capto
With MC2017, I can assemble the components in SolidWorks,
export a step file and build a factory accurate Mastercam holder is seconds
