Sign in to follow this
thanhsonnguyen
mastercam x4 invalid sim found -error code 2
invalid sim found -error code 2 , any one know how too fix that, some time it work some time, turn off and turn back on it error , lick 2 or 3 tim it work?
[ 01-23-2010, 10:02 PM: Message edited by: Supercar 2006 ]
Check the power settings and make sure USB ports are not being turned off. Also make sure the power management for the USB root hub in the Device Manager is not being turned off to save power by windows.
usualy it is an error, becouse you had pirat copy of mastercam na that comp. Only solution is format.
Check older posts. Use search!
Check older posts. Use search ?
Also make sure the power management for the USB root hub in the Device Manager is not being turned off to save power by windows.? where is it?
Question/Issue__________________________________________
(Sim) Error message: Invalid SIM found-error code 2, EXE not valid
Cause: Hasp emulator
Answer/solution____________________________________ V9
Delete or rename the following files. Hasp95.vxd & Hasp95DL.vxd These will be found in either the windows/system or windows system32 folder depending on the operating system.
X, X2
First search the entire hard drive for the following file. If it is found go ahead and delete it. “Haspm32”.
If you still receive the same error when trying to start the software then you will need to clean the registry of any indications of the HASP Emulator. Start by looking in the Registry (in both HKEY_LOCAL_MACHINE & HKEY_CURRENT_USER) for SystemCurrentControlSetServicesEmulatorHASP and delete it.
The attached file Emulaotr.txt contains additional entries emulator may install. There’s a chance that some of these will need to be deleted too in order to completely eliminate the error but start off with the first two steps.
X3
Everything listed under X,X2 as well as items listed below
Search registry and delete any XHasp entries.
Search and delete the following file XHasp.sys. It will typically be found in the system or system32 folder.
i try to seach that file can't find, any one can help
I beleive someone has installed a pirate copy of Mastercam on that machine. The easiest way to repair it a total reinstall of Windows including a C drive format
It may not come from Mastercam alone.
Aladdin is checking and they aren't telling anyone exactly what they're checking for but it could well be related to to something else that's installed.
Reformat the drive and reinstall.
Is Your OS is Vista ?
Are you running Net hasp ?
Did you try to disable UAC ?
:angry: Pirated Software!!
Absolutely, you cant run it like that Georgi. Its illegal
PEACE :D
Reformat the hard drive and re-install everything but the emulator
Thats a good one.. :D
Isn't it great that there is a mastercam sponsored forum where you can go to get help to get your cracked copy to work.
Mike
Mike
what instructions :rolleyes:
