Programming a metric tap when in inches mode
krosen
I have a job that I need to program a metric tap (which is unusual at our shop).  I selected a metric tap (when in inches mode) and thank the lord I ran the tap a couple inches above the part on the first hole because it wouldn't have been pretty.  I then read online that in order to program a metric tap in inch mode you have to use an inch tap and convert the tool geometry to metric.  is this correct? or is it possible to select and use a metric tap when in inch mode?
I just go to the thread per inch field of the tool definition and enter
1/ (metric pitch value mm) and let Mastercam do the work
so for a 1mm pitch thread
1/(1mm) = 25.4 threads per inch
a 1.5 mm thread would yield
1/(1.5mm)  = 16.933333 threads per inch
When you output the Feed value for a Tap, it's very important to check the format being output. Many times the control will accept 5 or 6 decimal places for a Tapping Feed Rate, but the output in the post might be set to 3 or 4 decimal place output. This can mean a slight error in the synchronization between the spindle rotation and the Z feed, which can cause a loss of precision in the tapped hole, and I've even seen where a 3 place decimal caused enough of a lead error to break a tap.
1/ (metric pitch vale mm) and let Mastercam do the work
exactly what i do for building molds / tooling with metric components.
The theory is pitch error. However, no deeper than *most* taps go I wouldn't worry about the 2nd or 3rd decimal places. I have seen the pitch finally stack up on holes that were threadmilled really deep but I also thought they were threaded way to deep. JM2C
I guess I've just been lucky. I've tapped 1000s of holes over the years and never seemed to have broken one because of pitch error. Maybe I was getting premature tap wear because of it and then when it finally broke, I chalked it up to a dull tap.
Awesome! I didn't realize till this post that MC interprets the "mm" automatically in entry fields. Thanks.
